200 si/GSR Problems
Old Sep 21, 2007 | 03:25 PM
E_F_9's Avatar
Default 2000 si/GSR Problems
more problems for the SI im throwing a C.E.L Electrical Load Detector defective circuit or unplugged / defective sensor and VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor . I replaced VSS and ecu but still the same **** im at a lost .Can anyone help or direct me in the right direction
2000 si gsr motor
Old Sep 21, 2007 | 04:10 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: 2000 si/GSR Problems (E_F_9)
sounds like something in the wiring...have your checked into that? try the ALT wiring and around the fuse box
Old Sep 21, 2007 | 04:15 PM
jdmjin's Avatar
you should wire the sensor straight to the ecu....it always helps because it skips all the wiring harnest (just incase thers a rip somewhere)....
i did with my IAT sensor and it work perfectly fine....it solve the problem!!!
Old Sep 24, 2007 | 11:00 AM
E_F_9's Avatar
its reading 12.34 -13.01 volts to the battery which in my mind is a lil low when you turn up the raido it shuts off like theres not enough power to it. I put a new ALT on and still same volts . the CEL is Electrical Load Detector so i thought maybe the ecu but still same **** . threre is no cuts in the wiring harnest at all .any one fill free to add
05civicdx
Honda Civic (2001 - 2005)
Feb 24, 2013 08:42 AM
94VXLSHatchie
Jul 6, 2006 03:57 PM
redlinez_r_us
Aug 14, 2005 09:09 AM
rainman
Jan 9, 2003 12:58 PM
