b18 into ef swap need insight
Old Sep 21, 2007 | 03:24 PM
Rexxer's Avatar
Default b18 into ef swap need insight
ok well, ive done many many swaps before yet this one seems to be plagued with problems.
to the point: car is running idle is really rough and it sounds like car is miss firing i have -- Checked timing numerous times, plug order. it started off you start it and it would die..due to the o2 sensor somehow. lol. unplugged o2 sensor. at idle fp is at 35 psi which is stock for b18 if can remember right. since i thought it was getting not enough fuel. and tps sensor keeps throwing a code at random times..going to clean it soon to fix that issue but. it seems like the car has no power and you floor it ..a geo metro could pull me start to finish. lol. i personally think cap/rotor could need a change...just wanting to know before i dump more pointless money into this car.
thanks.
-- its not that just changed rotor/cap and wires.
Modified by Rexxer at 12:55 AM 9/22/2007
Old Sep 21, 2007 | 04:02 PM
93'colttsi's Avatar
Default Re: b18 into ef swap need insight (Rexxer)
check ur valve and ignition timing....
Also check to make sure all the grounds are connectted properly... and after that confirm that all the vaccum lines are connected properly also.
Old Sep 21, 2007 | 04:21 PM
Rexxer's Avatar
Default Re: b18 into ef swap need insight (93'colttsi)
nope and nope, even added more grounds.
Old Sep 24, 2007 | 01:51 AM
Rexxer's Avatar
anyone else? =/ oh and the cars idle sounds like a lopy drag car.
Old Sep 24, 2007 | 10:56 AM
jakscivic's Avatar
Im pretty sure that the TBs are the same, but on my b16, when i rebuilt it, I accidently switched these two vacuum hoses around. They are right next to each other and it made my car run like total *** burgers.
But to me, it kinda sounds like a problem with a sensor not being plugged in or vacuum.
Old Sep 25, 2007 | 01:24 PM
Rexxer's Avatar
Default Re: (jakscivic)
well just incase anyone else stumbles upon this, it was the tps sensor (who knows why or how)
Lost216
May 27, 2020 06:49 PM
Boostin_Bubble
Sep 30, 2009 04:13 AM
lancerkid06
21
Mar 2, 2009 07:30 PM
itrintegra
Sep 24, 2007 07:31 PM
EFing8
Nov 7, 2002 04:13 PM
