Does anyone know how to hook this up?
this is the relay hooked up to the alarm system in factory 6th gen accords. this relay ties into the tail lights. i was wondering where does the white square with the metal plate in the middle of it go? its the one with the zip tie and it also has a wheel looking thing in the front of it [located on the left side of the pic] or does anyone have a sheet how this is suppose to all hook up?
well im not too sure...im just trying to fix a problem i have and see this as unconnected. since it has metal i was wondering where it connected to. i look at the wires around this one and they also have plugs with a metal plate in the middle
passenger side, below the glove compartment. u may have to remove the side floor panels to see it, maybe not. but its right where the carpet ends if that helps...on the right hand side
that does not look like it is plugged into any relays. i think it should be screwed to the frame as a ground. try finding a hole to screw that in. thats what i think unsure.
ur saying the white square should screw into a ground? i tried that but idk it doesnt work either....maybe i did it wrong or something.
i need to look at another accord to really see whats going on
wow ^^^ i appreciate u posting that. u went through the trouble of taking a pic in your ride then uploading it and posting.
LSteggyguy
Audio / Security / Video
Sep 10, 2012 08:55 AM
gjattili
Nov 4, 2008 07:51 AM
