Intermittent Starting Problem
Old Sep 20, 2007 | 10:41 PM
1Bluegsr's Avatar
Default Intermittent Starting Problem
I have a 91 civic with a gsr swap in it and it doesnt start about 5% of the time. About 5% of the time when I turn the key I can hear my fuel pump kick on but my car does not turn over at all. I replaced my battery and starter and check my battery connections but they were all good. I do not have my alarm integrated in the starting system right now. When it doesnt start I can turn my car to on and take a wire from positive of battery to remote wire of starter and it starts up everytime. I tested the volts at battery when I start it and they go down to 10. I tested the volts at battery when it didnt start and it goes down to 10 but at the remote wire of starter it only has 8 volts.
Old Sep 20, 2007 | 11:14 PM
SIred91's Avatar
Rainman
Default Re: Intermittent Starting Problem (1Bluegsr)
replace the box to starter wire and fuse. and check your main relay for corrosion.
Old Sep 25, 2007 | 02:27 PM
1Bluegsr's Avatar
Default Re: Intermittent Starting Problem (SIred91)
The under hood main starter wire from the under hood fuse box. Or the starter signal wire that comes from the under dash fuse box?
Old Sep 25, 2007 | 10:01 PM
1Bluegsr's Avatar
Bump
Old Sep 26, 2007 | 05:01 PM
konka's Avatar
check the starter silonoid. but b4 that check and clean all the grounds then give it a try. I had that problem and it was jsut a bad ground. let em no how it goes.
Old Sep 26, 2007 | 09:16 PM
1Bluegsr's Avatar
Default Re: Intermittent Starting Problem (konka)
But if the start solenoid was bad then why would my car start when I use a jumper wire to go from the positive terminal of the battery to the solenoid of the starter? I have check my grounds but I will double check them again. Thanks for the ideas
Old Sep 30, 2007 | 12:00 PM
1Bluegsr's Avatar
I havent figured it out yet. Has anyone else had this problem?
Old Sep 30, 2007 | 06:56 PM
Bserieskllr's Avatar
i actually have a similar problem but sometims when i got to start it u can hear the solenoid click but dosent turn over it usually goes after a few trys, but also sometimes when i go to do it i lose all power but i let it sit check the connection on the positive side of the battery (relocation to the trunk) and it works fine. but its not often usually after it sits overnight.
Old Sep 30, 2007 | 09:56 PM
1Bluegsr's Avatar
Default Re: (Bserieskllr)
It sounds like you got a bad starter solenoid or your battery is to low to start your car.
Old Oct 3, 2007 | 01:47 PM
konka's Avatar
Default Re: (1Bluegsr)
Bserieskllr sounds like u have a bad ground from the battery to where it hooks on the support. check that and get back to me.
tvdc2
Jul 29, 2016 08:48 AM
Schultzie
Jan 23, 2013 09:46 PM
Nathan_volcom
Aug 26, 2012 10:17 AM
TravisB16a
12
May 16, 2008 04:26 PM
mtber
Jul 14, 2004 09:02 AM
