Is their a certain tool to use on that?
Old Sep 20, 2007 | 09:37 PM
Efbucket's Avatar
Default Is their a certain tool to use on that?
Im pulling out my engine ive got everthing unplugged and the axels off but i got stuck on the shift linkage theirs like a pin i need to take out is their a certain tool to use on that?
Old Sep 20, 2007 | 09:39 PM
BILLETGRIP's Avatar
Default Re: Is their a certain tool to use on that? (Efbucket)
search "bitch pin"
Old Sep 20, 2007 | 09:54 PM
gnar kill's Avatar
Default Re: Is their a certain tool to use on that? (BILLETGRIP)
you need to hit it with a punch and drive it out....there are special punces with like a half sphere in the center that are for this they work good but you don't need them....just get the right diameter punch and whack away
Old Sep 20, 2007 | 09:58 PM
.Grimace's Avatar
footwork mastery
Default Re: Is their a certain tool to use on that? (gnar kill)
just use a smaller bolt and hit it out. not hard.
Old Sep 20, 2007 | 11:07 PM
SIred91's Avatar
Rainman
Default Re: Is their a certain tool to use on that? (.Grimace)
The AC compresssor mount bolts are perfect for that job.
On another note, glad to see you finally have the right name GREMICE/Grimace.
Old Sep 20, 2007 | 11:30 PM
.Grimace's Avatar
footwork mastery
Default Re: Is their a certain tool to use on that? (SIred91)
haha yes i got tired of everyone asking why i didn't spell it correct.
Old Sep 20, 2007 | 11:36 PM
90sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">The AC compresssor mount bolts are perfect for that job.
On another note, glad to see you finally have the right name GREMICE/Grimace.</TD></TR></TABLE>
On another side note. I actually have a Grimace tie.
Old Sep 20, 2007 | 11:55 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">haha yes i got tired of everyone asking why i didn't spell it correct.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan &raquo;</TD></TR><TR><TD CLASS="quote">
On another side note. I actually have a Grimace tie. </TD></TR></TABLE>
badass on both counts!
Old Sep 21, 2007 | 05:32 AM
GreenBean's Avatar
lol...I have a concrete drill got that fits the pin perfectly, it stays in my tool box next to my 3lb sledge hammer.
BTW that 3lb sledge is one of the most awesome helper tools in my tool box.
Old Sep 21, 2007 | 07:25 AM
gursh d's Avatar
I ran into the same problem when doing my swap. Check out the thread that I made, got some pretty good responses there:
https://honda-tech.com/zerothread?id=1993271
I tried the c-clamp method, AC compressor bolt, all different types of punches, but the pin didn't want to come out. So I ended up ordering a tool from Matco tools specifically designed to remove the shift pin.
Go to http://matcotools.com/ and search for this part number: MST6455
Took about 3 hits with a BFH and in 5 seconds it was out. It always helps when you have the right tools!
Old Sep 21, 2007 | 08:17 AM
SFlCrx's Avatar
"roll pin punch" i have the snap on kit but just go to sears
Old Sep 21, 2007 | 09:59 AM
GreenBean's Avatar
Default Re: Is their a certain tool to use on that? (91.crx.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si &raquo;</TD></TR><TR><TD CLASS="quote">It always helps when you have the right tools!</TD></TR></TABLE>
Amen, Amen and Amen
Old Sep 21, 2007 | 10:38 AM
RSZero1's Avatar
Default Re: Is their a certain tool to use on that? (GreenBean)
Wes also did a write up on this using a c clamp if you didnt have a hammer or space to swing one. Search User - Wes
Old Sep 21, 2007 | 11:08 AM
gursh d's Avatar
Default Re: Is their a certain tool to use on that? (RSZero1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSZero1 &raquo;</TD></TR><TR><TD CLASS="quote">Wes also did a write up on this using a c clamp if you didnt have a hammer or space to swing one. Search User - Wes</TD></TR></TABLE>
http://www.performanceforum.co....html
Old Sep 21, 2007 | 10:16 PM
Street Racer X's Avatar
Wes's site is great, will help you with the "bitch pin" and many other topics as well.
Old Sep 21, 2007 | 10:47 PM
Efbucket's Avatar
thanks everyone i finally got that bitch out! great link 91.crx.si
Old Sep 21, 2007 | 10:55 PM
Fuzzy Rhubarb's Avatar
Having autozone, advance etc. rent out that punch would be such a time (and money) saver. Petition time!
Old Sep 22, 2007 | 12:55 AM
grey_ghost's Avatar
Default Re: Is their a certain tool to use on that? (Fuzzy Rhubarb)
just a thought...not sure if your doing a b series swap or not but if you are what i did was disconnected everything disconnected the shifter dropped the engine down withe the linkage still attached why disconnect something you really dont have to...? please correct me if im wrong
Old Sep 22, 2007 | 03:16 AM
Wraith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si &raquo;</TD></TR><TR><TD CLASS="quote">I ran into the same problem when doing my swap. Check out the thread that I made, got some pretty good responses there:
Took about 3 hits with a BFH and in 5 seconds it was out. It always helps when you have the right tools!</TD></TR></TABLE>
i just got the same tool from matco too, its awesome, used it on 3 swaps already, and everytime it comes easy.
Coolero
Dec 30, 2007 10:41 AM
averyvm
Jul 23, 2007 04:45 PM
leroyb
Apr 4, 2007 11:26 AM
typeeg
Jun 7, 2004 10:44 AM
MikeMAN
Jul 17, 2003 06:38 AM
