Problem with B20Z swap...
Old Jun 17, 2002 | 04:47 PM
b18cef's Avatar
Default Problem with B20Z swap...
My bro has a B20Z swap in his EG. His motor skips between 1k and 3k rpms.
His setup consists of:
-B20Z
-Skunk2 manifold
-B&M fuel regulator and gauge(39psi)
-intake
-cat back exhaust
-94 LS computer
Does anyone have any clue why it may due this?
Thanks in advance!
Old Jun 17, 2002 | 05:08 PM
cinq's Avatar
Default Re: Problem with B20Z swap... (b18cef)
maybe when he replace the intake manifold...he has a leak somewhere??? check the trottle body...and between the intake gasket.
Old Jun 17, 2002 | 05:09 PM
Paul Walker's Avatar
What do you mean by skips? Can you be a little more specific?
Old Jun 17, 2002 | 05:18 PM
b18cef's Avatar
Default Re: Problem with B20Z swap... (Paul Walker)
The motor hesitates when you give it the gas(full throttle) in that rpm range.
Old Jun 18, 2002 | 03:19 PM
b18cef's Avatar
Any suggestions???????
Old Jun 18, 2002 | 07:09 PM
intake's Avatar
B A N N E D
go to the Import shop and let professionals check it out..
Cant always rely on internet guru's..
Old Jun 18, 2002 | 07:16 PM
spettinger's Avatar
Default Re: Problem with B20Z swap... (intake)
be certain that you have the proper throttle body gasket, and proper intake manifold gasket. if that doesn't do it, replace the fast idle valve on the back of the intake manifold.
johan60
May 6, 2016 01:08 PM
949
Sep 20, 2010 01:50 PM
Integacivic
Jul 31, 2004 01:59 PM
joecivic93
Jan 3, 2004 10:25 PM
