New starter, car won't start
Hello all. I just replaced the starter on my car less than a month ago (because it wasn't starting), and it ran fine. Started up right away everytime, and then out of the blue, my car wouldn't start. Won't turn over at all.
Have a new starter
New ignition switch
New battery
fuses are good
Cleaned all the grounds
Could the dizzy/plugs/wires cause the motor to not turn over at all? All I get when I try to start it is a click. Fuel pump primes too. Thanks for any help!
-Shane
Have a new starter
New ignition switch
New battery
fuses are good
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">Hello all. I just replaced the starter on my car less than a month ago (because it wasn't starting), and it ran fine. Started up right away everytime, and then out of the blue, my car wouldn't start. Won't turn over at all.
Have a new starter
New ignition switch
New battery
fuses are good
-Shane</TD></TR></TABLE>
i would return the starter. i went trough 3 autozone starters for my b16 before they got it right. quite fustrating actually.
Have a new starter
New ignition switch
New battery
fuses are good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">i would return the starter. i went trough 3 autozone starters for my b16 before they got it right. quite fustrating actually.</TD></TR></TABLE>
That's now what I'm thinking. My roommate and I just went up to see if we could get anything else to get it running. Took the starter out, made sure it spun freely, and cleaned the positive battery terminal (since it looked a little corroded). We also tested the battery just for giggles.
Put everything back together, and sometimes we could hear a click come from the starter, but the motor still wouldn't turn over.
Last resort, we push started it and it fired right up. Drove it back to the house, turned it off and tried restarting it, same thing as before.
Do you think for the extra $100 a reman starter from Honda would be better? I am really thinking those may be the better way to go.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">Bump for Honda reman starters??-Shane</TD></TR></TABLE>
I'm guessing nobody has had experiences with Honda (reman) starters.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">if you push started and it started, i would change the starter for a new one</TD></TR></TABLE>
I've figured that out, but do you or anyone else think that a reman from Honda would be more reliable than a reman from Autozone? I mean, I've already been through 2 in less than a month, and philosofy1 tried 3. I want to sell my car, but want it to be reliable, so I don't want to get a junk starter.
-Shane
-Shane
have you tried jumping the starter posts with a screwdriver? if it works... could be an ignition or starter solenoid problem.
Also check the ground wire that goes from the body to the tranny. I had the same issue.. cleaned the grounds. They looked perfect and it still did not work. Then looking at the wire that goes from the body to the tranny... I saw that it had a bulge in it.. so I cut back the casing and found that it had a ton of corrosion. replaced it with a new wire... and bam.. fired right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayjay »</TD></TR><TR><TD CLASS="quote">have you tried jumping the starter posts with a screwdriver? if it works... could be an ignition or starter solenoid problem.
Also check the ground wire that goes from the body to the tranny. I had the same issue.. cleaned the grounds. They looked perfect and it still did not work. Then looking at the wire that goes from the body to the tranny... I saw that it had a bulge in it.. so I cut back the casing and found that it had a ton of corrosion. replaced it with a new wire... and bam.. fired right up.</TD></TR></TABLE>
Well, since we could jump start it, that would be the same as jumping the starter motor (i.e. bypassing the solenoid), so the conclusion is the solenoid is bad. This we figured out after my original post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robfrmny21 »</TD></TR><TR><TD CLASS="quote">oem new or oem remans are great better then auto zone crap</TD></TR></TABLE>
This is what I wanted to know. I did read in another post as well that people have had some trouble with aftermarket. Thanks for the info!
-Shane
-Shane
wastedfaith
38
Jul 10, 2011 03:14 PM
Timmyflys
28
Jun 25, 2007 03:11 PM
HybridGSR1
Jul 13, 2004 02:16 AM
