low compression need help
Old Sep 20, 2007 | 01:10 PM
2000siturboR's Avatar
Default low compression need help
ok heres the deal motor is a b16a2 running 7 psi. about a month ago cel came on did a scan random misfire in cylinder 1,2,3,4. changed plugs and wires didnt fix it. so before i decided to go out and buy other **** did a compression test results came out bad. cylinder 1-160 cylinder 2-90 cylinder 3-160 cylinder 4- 90. did a leak down test the really didnt hold alot of air. at this point im thinking more maybe broken valve springs or bent valves. but also thinking rings are bad not sure. any one with some input i would appreciate it thanks.
Old Sep 20, 2007 | 01:35 PM
Dasfinc's Avatar
Default Re: low compression need help (2000siturboR)
Leakdown test should really help pinpoint Valves or Pistons.
I hate to say it, but I think its the Pistons because #1 and #4 are go TDC, then #2 and #3, so Leaks at 2 and 4 doesn't make me think bent valves as valves I'd imagine would be all 4, or a rotational pair like 1+4, or 2+3
Old Sep 20, 2007 | 01:39 PM
97Ej6mike's Avatar
Sometimes it doenst have to do with pistons, if you have 2 adjacent cylindars that show low comp, then that could also mean you have a blown or weakened head gasket
Old Sep 20, 2007 | 01:43 PM
Dasfinc's Avatar
Default Re: (97Ej6mike)
If the headgasket is weakened/leaking he'd have SERIOUS power issues and be blowing alot of white smoke I'd imagine?
Old Sep 20, 2007 | 01:45 PM
luvmihatch's Avatar
Default Re: (Dasfinc)
if u cant tell by the leak down test then i would pull the head off maybe head gasket or rings.. but id go with rings bc ur compression is shot to sht. good luck
Old Sep 20, 2007 | 02:00 PM
Default Re: (luvmihatch)
yea the thing is i have a significant power lose and its not head gasket cause i holding water thats why im thinking more of rings or valves
Team_Coast978
Aug 24, 2013 09:31 PM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
2000siturboR
Sep 21, 2007 11:20 AM
Da1spaz247
Nov 4, 2005 07:57 PM
RABBIT9
Jun 2, 2003 04:35 PM
