The Clutch or the Transmission? That is the Question...
Old Sep 19, 2007 | 10:11 PM
old_school_dohcvtec's Avatar
Default The Clutch or the Transmission? That is the Question...
So today I was driving to the local store and I started to notice it got really hard to put the car into gear and also really hard to take it out of gear.
I went into the store then came out. Started the car, tried to put it into gear and it wouldn't go in. When i tried to put it in gear, the car would jerk forward alittle.
You know the feeling when you try putting the car into gear without pressing the clutch? It jerks forward alittle.... That is how it felt for me even when pushing the clutch in!
I changed the clutch fluid, no luck.
Help me please! thanks.
Old Sep 19, 2007 | 10:28 PM
frontwheelfanatic's Avatar
Default Re: The Clutch or the Transmission? That is the Question... (old_school_dohcvtec)
Its probably your clutch, but replace the clutch master and slave cylinders first. I had the exact same problem 2 weeks ago. And all 3 of those things failed on me at the same time giving me the symptoms you got
Old Sep 20, 2007 | 02:29 AM
roger93si's Avatar
Default Re: The Clutch or the Transmission? That is the Question... (frontwheelfanatic)
yea sounds like a clutch problem.
when was the last time it was replaced?
Old Sep 20, 2007 | 03:08 AM
Exeed's Avatar
Default Re: The Clutch or the Transmission? That is the Question... (roger93si)
If the pedal comes back up after pushing it in, it's most likely not your master ans slave clutch cylinders. If it comes back up, it's most likely either your pressure plate, or your hub springs have gone bad. I think that's what happened to my brother as well. Either way, I think it's appropriate that you buy yourself a new clutch, pressure plate and flywheel if you can afford it. Don't forget release and pilot bearings.
Old Sep 20, 2007 | 09:04 AM
dimwitrj's Avatar
Sounds like one of your springs on the friction disc broke off.
Old Sep 20, 2007 | 10:13 AM
p nut's Avatar
99.9% sure it's your clutch. Does/Did it make a whirring sound when you pressed the clutch in?
Old Sep 20, 2007 | 11:28 AM
Default Re: (p nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut &raquo;</TD></TR><TR><TD CLASS="quote">99.9% sure it's your clutch. Does/Did it make a whirring sound when you pressed the clutch in?</TD></TR></TABLE>
yea the "whirring" sound comes on and off. Its weird
THANK YOU GUYS FOR THE HELP, I REALLY APPRECIATE IT!
Old Sep 20, 2007 | 11:32 AM
12KRPM's Avatar
Default Re: (old_school_dohcvtec)
Sounds like a pressure plate.. Well take it to someone who knows
Old Sep 20, 2007 | 02:49 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (p nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut &raquo;</TD></TR><TR><TD CLASS="quote">99.9% sure it's your clutch.</TD></TR></TABLE>
Old Sep 23, 2007 | 09:29 AM
gofastgokart99's Avatar
They call me the part of a womans vagina that causes pleasure.
Default Re: (CleanLikeJdm)
prolly slave, mine went 2 days ago, except my pedal went to the floor and didnt come up....
Old Sep 24, 2007 | 12:51 PM
Thanks for the replies guys... I took it to the shop and it was the clutch. I now have an exedy clutch so its all good
thanks for the help.
Old Oct 4, 2007 | 09:47 AM
nice choice on tha clutch
codybb4
Dec 9, 2008 08:44 AM
Hemix
11
Jun 30, 2008 11:25 AM
snzh22
Apr 29, 2008 09:22 AM
dexy
Jan 11, 2005 09:53 AM
93civcx
Jun 18, 2004 06:25 AM
