93 Integra Cluster into 92-95 Civic. DIY
If anyone wants me to do a write up on how to do this I will.
I have it 99% done and can start doing a write up as soon as Friday.
The 93 Integra cluster is not compatible with the 94+ Integra cluster wiring guide also found on this forum.
This cluster AND harness' cost me about 3 times less then a 94+ cluster and looks exactly the same minus the carbon face. But who cares about a carbon face its all about the gauge placement. So anyways, tell me if you are interested and I will do a write up!
Thanks all!
Mike
Thanks all!
Mike
any DIY write up is worth it reading. if it doesn't inspire someone to do it the least you can get out of it is respect for being innovative.
Alrighty Im gonna start the write up Thursday night and it should be finished by Saturday or Sunday.
***HEADS UP!!::
I had to do A LOT of custom wiring so I have to retrace a bunch of steps. Also you'll have to modify the cluster shroud and the shroud around the dash to fit the clock and cluster in. Although this sounds like a lot of work it will cost almost no money. To custom fit the stuff you just need a hack saw and a thick drill bit.
Im probably going to be relocating the clock AND my cd player. CD player is probably going into the glove compartment along with a cd holder rack. And the Clock where the CD player was and then something awesome where the clock used to be. Once I make the custom mounts for this stuff Ill make ANOTHER write up for all this.
When I do the write up Ill edit the first post so STAY TUNED TO THIS TOPIC and check in everyday.
***HEADS UP!!::
In for the writeup. How do you convert the standard electronic VSS to work on a cable driven speedometer? Do you have to buy a cable VSS and route it through the firewall?
danomatic93
51
Mar 25, 2011 09:01 PM
smileydub
Feb 21, 2010 07:51 AM
Calvinator
Northern California (Sales)
Dec 19, 2006 11:21 PM
