VTEC Basics...
Old Sep 19, 2007 | 03:11 PM
fatpride111's Avatar
Default VTEC Basics...
ok, im new to hondas and this forum, so bare with me please, i searched for some topics, but non really had any info that i was looking for.....
my questions are, whats the difference between normal VTEC, and i-VTEC...
also, when VTEC hits, what exacly opens the valves more, does the cam drop... or does it have other lobes that it switche out when oil pressure gets higher?
i HAVE looked up VTEC info on wikipedia, but its in smart people language, and as u can tell, im an idiot... i need someone to dumb it out for me please
Old Sep 19, 2007 | 03:14 PM
JKov240's Avatar
Default Re: VTEC Basics... (fatpride111)
http://en.wikipedia.org/wiki/VTEC
Old Sep 19, 2007 | 03:25 PM
whats the difference between i-vtec, and normal vtec?
Old Sep 19, 2007 | 03:28 PM
posHonda's Avatar
The "i" in ivtec stands for intelligent. Honda engineers found that the original VTEC was retarded and came out with a more intellgent system.
Old Sep 19, 2007 | 03:35 PM
what makes it "inteligent" ....?
Old Sep 19, 2007 | 04:10 PM
polishrifle's Avatar
Default Re: (fatpride111)
I believe that the only difference is that the i-VTEC has a switchover point (RPM) that changes depending on engine load, when the regular VTEC switchover point is fixed.
Old Sep 19, 2007 | 04:57 PM
so meaning.... if u slowly rev up the motor, i-vtec wont engage, but if u floor it at a low rpm, itll engage at a low rpm as soon as it realizes u wanna go fast?
... and normal vtec will engage at say.... 5500 rpm either way if u floor it or get there slowly?
Old Sep 20, 2007 | 09:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatpride111 &raquo;</TD></TR><TR><TD CLASS="quote">so meaning.... if u slowly rev up the motor, i-vtec wont engage, but if u floor it at a low rpm, itll engage at a low rpm as soon as it realizes u wanna go fast?
... and normal vtec will engage at say.... 5500 rpm either way if u floor it or get there slowly?</TD></TR></TABLE>
You would be correct, except that the point on the regular VTEC is usually lower than 5500, it's 4800 on my D16 for example
My explanation is a bit brief though, it really does depend on a lot more than that, but in a nutshell that is what is going on. Once you learn a little more, go back and check out wikipedia.
Old Sep 20, 2007 | 10:03 AM
AWD Terror's Avatar
Default Re: (polishrifle)
I think this is about the 10th time I've posted this link...
http://www.team-integra.net/se...ID=45
Old Sep 20, 2007 | 10:04 AM
AWD Terror's Avatar
Default Re: (AWD Terror)
And in case you couldn't find this link in the one above....
http://asia.vtec.net/article/k20a/index.html
Old Sep 20, 2007 | 10:08 AM
RIZOBIZERT's Avatar
The 'I' in Ivtec represents the ability of the cams to adjust the cam angle. Are you familiar with 'adjustable cam gears'? Well, Ivtec does this constantly as the ECU sees fit for the motor to do so. Generally this happens at higher RPM's. I hope this helps.
Old Sep 20, 2007 | 10:12 AM
drtysohc's Avatar
VTC is the difference between i-VTEC and VTEC.
Old Sep 20, 2007 | 10:26 AM
B18CivicEJ8's Avatar
http://www.youtube.com/watch?v=AcT_ZyY3F0k
That should help... This is an explanation of older VTEC technology. Meaning on D16, B16, and B18C motors...
http://www.youtube.com/watch?v=ECB5yFaWmVM
The second vid describes i-VTEC...
Modified by B18CivicEJ8 at 11:40 AM 9/20/2007
Sipey
Aug 12, 2012 06:23 AM
T-Charged-Civic
Feb 9, 2006 01:37 PM
Brown-tec
Nov 13, 2005 08:39 PM
VwGti200
Apr 29, 2003 02:46 AM
HorrorDog
Nov 11, 2001 09:32 PM
