Need help with my little project.
Ok guys so i bought this car for cheap and had it for a while and my engine bay looks like crap dont have alot of money to work with but i wanna make it look nice at least and i have a lot of time on my hand anyway. i wanted to pull the engine out and see if i work on my bay,, i wanted to do it flat black. my only doubt is how to actually pull it out and the axles how do you remove those??? basically thats my main point. how can i remove the axles everyting thing else i can just just tape with color to remmeber what i need. i want the ngine bay as clean and empty as possible anyone see anything i can remove that i really dont need???
uncoverd her and did a few things since i was home bored
started removing some things just to get ready to paint this sucker i hate this purple crap..no offense to those who have ..just not my style ya dig??
well this is garbage!!! god dam!!anyone got one for cheap man holla at me with anything better than this help me out
and all for now wasnt much but hey then it was billard time so i had to ride...
Modified by H22CIVICJDM at 7:37 AM 9/28/2007
i know what will make it look more clean take the motor out and give it to me! hahah! but don't really see anything else. you could do a wire tuck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CIVICJDM »</TD></TR><TR><TD CLASS="quote">
different...but anyone know a write up or something that can show me how to remove those axles..only thing really bothering me i wanna wtake this suckers out and flat black this bay
401 posts and you can't find the axle howto using the search button?
John
</TD></TR></TABLE>401 posts and you can't find the axle howto using the search button?
John
yeah, it is sort of sad you can't find the faqs..
Just shrink wrap the motor in the bay. Support the engine on some blocks or something, and just wrap it up in the bay, that way you can disconnect everything and not worry about having to pull the motor.
and um, go to the main page for this forum, go to the top it says FAQ's (which is short for frequently asked questions)
there is a walk through to removing axles...
Ok guys im NOT done yet and this is only temporary just to make it look clean for now..... ive decided i will be painting the car black not RED so to pay less i will be painting my whole interior myself...and black should be cheaper to paint that red huh??
Modified by H22CIVICJDM at 7:44 AM 9/28/2007
Modified by H22CIVICJDM at 7:45 AM 9/28/2007
there's a couple of ways to take the axles out.
First Way:
passenger side:
the easiest way but takes a little longer is to unbolt the axle nut(32 mm) then just unbolt the fork bolt, and the other three bolts that connect the control arm or whatever that arm is and move it out of the way so the axle can then be pulled out. dont yank on the axle too much or you can mess up the bushings. get a pry bar or something to try and pry between where the axle and tranny meet.
as for driver side:
Same as passenger but....
unbolt the three bolts where the midaxle bolts to the block!
should come out fairly easy compared to the passenger side!
Second Way:
Easy only if your castle nut bolt from under the spindle comes off easily.
Passenger side:
Unbolt the axle nut(32 mm)
unbolt the fork nut and bolt
pry the axle out as stated above.
Driver side:
same as passenger but....
unbolt the three bolts where the midaxle bolts up to the block!
there might be a little detail that i might not have added but pretty much the gist of it all!
or you can drive all the way up to CT and ill do it for you for only 3 easy payments of 1 BILLIONS DOLLARS!
First Way:
passenger side:
as for driver side:
Second Way:
Passenger side:
Driver side:
So, let me get this right. You have an H22 swapped civic and you don't know how to take axles out?
AND you want to paint your engine bay flat black, just like every other dumbass that paints engine bays? At least to id gloss black. Flat black looks great for about 20 minutes. Then you get something on it or scratch it, and it's all down hill.
Do yourself a favor and just do a wire tuck. You'll thank me after you see a few flat black engine bays on other daily drivers. They always look like crap after a few months.
appreciate the help however i feel theres no need to disrespect other people for what they have done or even call them names. Ill try the glossy black better thanks for the input by the way.
take out the ac lines on the by the passenger strut tower... you don't have ac you don't need them
second i would remove every piece of that red lum... imo nothing looks worse when trying to do a wire tuck then colored lum...
just pull the harness out put black lum on it and then tape it up if you want it to look really clean
change the radiator hoses to black also.
you could paint your valve cover if you want it to stand out if you want it smooth you can use aircraft remover to pull everything off... then paint with heat paint
also you can hide that pasenger side headlight harness wire by runing it below the frame (zip tie it along the way so that it isn't just dangling loose somewhere)
then last but not least when you put the harness back in just make sure you hide as many wires as possible, and you can take some cleaning suppy and clean grease and dirt off your engine bay... these steps will make it look much better imo
man you know what i wanna say thanks for all the help i am writing these tips down and will not forget.....saw this guys engine bay well actually i saw his whole car but i saw his bay since im working on mine..lol....he wants to trade his car for a clean teggy!! I like the way he did his...but about that ......GLOSSY BLACK>>OR FLAT BLACK????
my most recent shot but not close....will take one up close if u notice i did some black taping....so its getting there but this weekend im planning to piant the bay..
GLASSY BLACK OR JUST FLAT BLACK??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CIVICJDM »</TD></TR><TR><TD CLASS="quote">thanks im still searching and nothing....but thanks for that comment</TD></TR></TABLE>
Hrm. You better get help with the axles then.
Search term used: replacing axles - forum (this one) - archived content
https://honda-tech.com/zerothread?id=174929
Took me about 15 seconds. What's your problem other than being snippy?
John
John
hey look i appreciate your help however please dont call me any names ...i respect everyone so theres no need for that..i will check out that page.....again thanks alot
just be prepared if you rattle can the engine bay the color will wash and chip off fast, or if you spill brake fluid..... i would reccomend using dual stage flat black at a profesional paint store or dont do it at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">just be prepared if you rattle can the engine bay the color will wash and chip off fast, or if you spill brake fluid..... i would reccomend using dual stage flat black at a profesional paint store or dont do it at all.</TD></TR></TABLE>
hey thanks....but really for my bay im just wanting to do something to make it look better....dont want like perfect but i want it to be better yes i have time the car is not being driven its in my driveway all day so i just figured i wanted to clean the bay along with all th eother work i need done.....will be registering and hitting the streets in about a month or two so i gots time
but thanks...can i pick that dual stage flat black in a can maybe autozone or autoparts??? and should i do a basecoat??
