power window prob. help!
Old Sep 19, 2007 | 08:22 AM
slowSOHCvtec's Avatar
Default power window prob. help!
my power window seems to be off track, it goes down ok but when i put it up the front part of the window goes onto the outside of the seal where the mirrors are and jams up. is there any way to get it back on the track without ripping the whole fing door panel off? i can get the window about 3/4 up so i know its not the motor. thx
Old Sep 19, 2007 | 08:42 AM
LetAGrlShowU's Avatar
Default Re: power window prob. help! (slowSOHCvtec)
i cant help, but i was wondering if u had any signs before it got to that point. on my '00 EX my passenger side window is real slow... assuming its just the motor. but hey its worth asking.
Old Sep 19, 2007 | 10:58 AM
bump for any helps??
Old Sep 19, 2007 | 11:08 AM
JDean6pac's Avatar
you have to take off the interior door panels put it bak correctly
Old Sep 19, 2007 | 11:23 PM
jers99's Avatar
Default Re: power window prob. help! (JDean6pac)
No way bro. U gotta take the pannel out. My does the same thing I've done it 100x's after the 2nd time u can prob have down to fixing it in 15mins tops. Mine usually does it when its cold or rainny out. Its not hard u just gotta play with the track u'll figure it out
Old Sep 21, 2007 | 11:39 AM
Default Re: power window prob. help! (jers99)
problem solved, the window fell off the front track, so i ended up just taking off the whole door panel, total time ~30 minutes first evolotion is not too shabby...thanks for all the help!
oh and btw i lubed up the channel with plenty of silicone grease so now my window is cruisin like a champ!
Old Sep 21, 2007 | 12:10 PM
MIKE_HWD's Avatar
yo mine is the same exact problem slow passenger and always comin off track driver does yours still come off track?
Old Sep 21, 2007 | 04:33 PM
Default Re: power window prob. help! (MIKE_HWD)
not anymore, it only popped off once, the door panels are pretty easy to take off (a few screws and some plastic plug things), once the door is off you will see the window where its held to the scissor actuator with two bolts on the front and back of the window.
only one of the wheels on the actuator moves, the other is stationary, so i just lubed up the whole track and put it up and down a couple times. make sure the bolts are tight that keep your track aligned and keep the window in the actuator if not a repeat problem is sure to occur!
central_driver
49
Sep 25, 2012 06:51 PM
juandaman
Sep 19, 2008 06:17 AM
jonboy07
Oct 18, 2004 12:30 PM
Matt B
Jan 14, 2004 08:50 AM
EX-T
Nov 27, 2003 07:26 AM
