93 civic si transmission problems
what sup everyone im having a few problems with my transmission and i want to see if ya can give me an idea whats the problems...When i shift into 2nd gear it grinds and just shoots right back out but all the other gears are fine. Is it my clutch , transmission , synchronizer . etc ?? ..When im just in park and just go do thru all the gears i feel grips on 1st , 3rd , 4th , 5th but 2nd just slip right in...sorry if ya dont understand i aint got no knowledge about engines/transmission
i had the same problem just after i put in a 93 trans, its poping back up sometime, try to tight ur shifter or even change it if still stock, the bearing in t might be kinda old, my shifter is moving just like in neutral even in gear, not a good thing lol
my 94 civic is doin the same thing with the 2nd gear.. like i can shift 1st 2nd 3rd but can't downshift back in to 2nd from 3rd.. if i try to it grinds or pops out of gear what could be problem friend at local shop said synchro's are going bad if so where can i buy new ones from or do i have to get a new transmission all together ??? thanx
1992, 2nd, 93, civic, gear, gears, grinds, honda, problems, si, synchronizer, synchronizers, transmision, transmission, whines
