no boost integra ls motor 1990
Old Sep 19, 2007 | 06:41 AM
teamunek1's Avatar
Default no boost integra ls motor 1990
my car will not boost i have gone and looked everything it could be but still no boost i have 1990 acura integra motor in my hatchback. i have the t3/t4 turbonetics turbo, 255 walbro fuel pump, 320 injectors, fmu, skunk 2 manifold, check valves for the map sensor, all piping and intercooler all together. and also turbonetics wastegate set at 9 psi. i have two check engine lights on its o2 sensor and the idle air control valve what can it be why can't i boost
Old Sep 19, 2007 | 06:55 AM
Hondaruss's Avatar
Default Re: no boost integra ls motor 1990 (teamunek1)
are you sure you have no leaks with the IC piping . And are you sure you dont have any exhaust leaks? IE the manifold to turbo. etc. also do you know for a fact that the waste gate is closed and hooked up correctly.
Just general questions to ask to further assist you.
Old Sep 19, 2007 | 07:02 AM
teamunek1's Avatar
Default Re: no boost integra ls motor 1990 (Hondaruss)
I'am pretty sure because i also took it to a shop and they said is all need was bigger injectors like 320cc because i had stock ones at that time but i got 320cc and it still does the samething
Old Sep 19, 2007 | 07:42 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamunek1 &raquo;</TD></TR><TR><TD CLASS="quote">my car will not boost i have gone and looked everything it could be but still no boost i have 1990 acura integra motor in my hatchback. i have the t3/t4 turbonetics turbo, 255 walbro fuel pump, 320 injectors, fmu, skunk 2 manifold, check valves for the map sensor, all piping and intercooler all together. and also turbonetics wastegate set at 9 psi. i have two check engine lights on its o2 sensor and the idle air control valve what can it be why can't i boost</TD></TR></TABLE>
First off, please try to type in complete sentences. You'll have more luck getting people to help if they don't have to sit for 5 minutes trying to figure out what you're asking. Anyways.
Not getting boost can only be a couple of things. One is the wastegate being open. I assume it's external? Check it again to see if the spring is installed, installed correctly, or that it's not broken.
Another possibility is you have a massive exhaust leak.
And finally the turbo could be junk.
But you have other problems to address as well. Like running 320 injectors and an FMU. I'm sure the car runs and idles like crap and the CEL for the o2 sensor is an over rich condition, yes?
If a shop told you that you need larger injectors to solve your no boost issue then you need to find a different shop. You obviously don't know much about boosting and this shop is either assuming that you do or they're taking advantage of you.
Larger injectors REQUIRE tunable engine management. If you're keeping the FMU, then you have to put the stock injectors back in.
Old Sep 19, 2007 | 08:25 AM
teamunek1's Avatar
Default Re: no boost integra ls motor 1990 (Buzzbomb)
runs good with the 320 injectors idles fine. Had stock injectors in there and it would do the something not boost everything i have is brand new turbo, wastegate, and everything you need turbocharge a car. Have turbocharge four other cars before and never had problem like this one
gary1234
Engine Management and Tuning
Oct 30, 2012 01:14 PM
jagged4698
Nov 14, 2004 02:49 PM
Escabar
Oct 12, 2003 01:53 AM
red cx
Jul 25, 2003 10:07 AM
Onefastteg
Mar 11, 2003 06:30 AM
