Radiator support, Does this need to be welded in?
Old Sep 19, 2007 | 06:21 AM
standbackimapro's Avatar
Default Radiator support, Does this need to be welded in?
Old Sep 19, 2007 | 06:22 AM
AWD Terror's Avatar
Default Re: Radiator support, Does this need to be welded in? (standbackimapro)
Not at all, just throw it at your car, and it will stay.
Old Sep 19, 2007 | 06:26 AM
audiko4's Avatar
Default Re: Radiator support, Does this need to be welded in? (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">Not at all, just throw it at your car, and it will stay.</TD></TR></TABLE>
Old Sep 19, 2007 | 11:43 AM
highlandparkbigpimpn's Avatar
Default Re: Radiator support, Does this need to be welded in? (audiko4)
yes it does need to be welded !
Old Sep 19, 2007 | 11:47 AM
crazyguy's Avatar
Default Re: Radiator support, Does this need to be welded in? (highlandparkbigpimpn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highlandparkbigpimpn &raquo;</TD></TR><TR><TD CLASS="quote">yes it does need to be welded ! </TD></TR></TABLE>
thats what i thought too..cause i remember i asked a friend from a body shop before and he said yes.it needs to be welded
Modified by crazyguy at 1:09 PM 9/19/2007
Old Sep 19, 2007 | 12:07 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audiko4 &raquo;</TD></TR><TR><TD CLASS="quote">
WTF?! are you guys serious? i really hope not, becuase if you were you have to be the most retarded people on here.
and if you are joking, please keep your jokes to yourself.
OP, you can have the radiator supprt welded on by a welder or a body shop.
you can also bolt it up yourself, which will save you money.
good luck!
Old Sep 19, 2007 | 12:15 PM
AWD Terror's Avatar
Default Re: Radiator support, Does this need to be welded in? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
Of course I'm serious. I did a JDM front end swap on my buddies 99 GS-R. We stood on the opposite side of the garage and got a running head start. We SLAMMED that **** on there hard enough to make it stay.
Old Sep 19, 2007 | 12:18 PM
philosofy1's Avatar
Of course I'm serious. I did a JDM front end swap on my buddies 99 GS-R. We stood on the opposite side of the garage and got a running head start. We SLAMMED that **** on there hard enough to make it stay.</TD></TR></TABLE>
ok, very funny. play time is over. lets get back to the topic.
Old Sep 19, 2007 | 12:20 PM
AWD Terror's Avatar
ok, very funny. play time is over. lets get back to the topic.</TD></TR></TABLE>
Ok.
Yes. You do need to weld the rad support in. If you want to bolt it in, go a head. It will save money, but I would want the assurance of knowing it's not going anywhere.
Old Sep 19, 2007 | 02:32 PM
why would you even try to bolt it in? it is a sure thing that its gonna come lose in no time. i would do it the right way and weld it in that also make the car safe if you crash it its not to hard if you have a welder or even rent one, and know how to use it
Old Sep 19, 2007 | 02:34 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highlandparkbigpimpn &raquo;</TD></TR><TR><TD CLASS="quote">why would you even try to bolt it in? it is a sure thing that its gonna come lose in no time. i would do it the right way and weld it in that also make the car safe if you crash it its not to hard if you have a welder or even rent one, and know how to use it </TD></TR></TABLE>
it wouldn't come loose if you use lock nuts!
Old Sep 19, 2007 | 03:24 PM
luvmihatch's Avatar
duck tape a peice of string and some chewinggum will work
so yeah ti does need to be welded iun its just a few spot welds nothing terribe. had to do mine when the engine hoist broke and bent it... ooops
Old Sep 19, 2007 | 03:37 PM
slaberdy's Avatar
Default Re: Radiator support, Does this need to be welded in? (luvmihatch)
lmao they are just tack welds... not a whole lot stronger than just bolting it down.
Old Sep 19, 2007 | 04:02 PM
simplegreenmachine's Avatar
Default Re: Radiator support, Does this need to be welded in? (slaberdy)
JB weld FTW
Old Sep 20, 2007 | 06:55 AM
No need to be counter productive, i just didnt know if it NEEDED to be welded or if it bolted up
Old Sep 20, 2007 | 10:06 PM
JDM-ish's Avatar
Default Re: (standbackimapro)
how can you have over a thousand posts and not know if the radiator support is supposted to be welded on?
Old Sep 20, 2007 | 10:18 PM
92VXeg's Avatar
radiator supports are overated anyway....
Old Sep 21, 2007 | 11:47 AM
LATINOSPEED's Avatar
YEAH BUT I WOULD NOT WANT TO BE IN IT IF YOU WRECKED
Old Nov 3, 2007 | 09:14 AM
blah blah blah's Avatar
Default Re: (JDM-ish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-ish &raquo;</TD></TR><TR><TD CLASS="quote">how can you have over a thousand posts and not know if the radiator support is supposted to be welded on? </TD></TR></TABLE>
well some arnt... i know my s10 rad support is bolted on....
Old Nov 3, 2007 | 09:16 AM
uptownspeedstar's Avatar
i've bolted on many radiator supports. you'll be fine.
Old Nov 3, 2007 | 09:23 AM
polything's Avatar
we weld it in.
Old Nov 3, 2007 | 09:38 AM
instrument's Avatar
if we were superheros we could simply use our heat vision!
Old Nov 3, 2007 | 09:47 AM
Syndacate's Avatar
<FONT SIZE="6">Holy **** ****, it needs to be welded, end of story.</FONT>
Old Nov 3, 2007 | 09:54 AM
Sketch_hs's Avatar
You can bolt it on just fine but its better to weld it up, make sure you align it right
Old May 22, 2024 | 12:22 AM
RuSureBoutThat?'s Avatar
