Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
3rd Brake light
Old Sep 19, 2007 | 03:21 AM
kroze's Avatar
Default 3rd Brake light
Anyone know where is the fuse located? I checked every fuse under the dash and under the hood but they all looked fine. The bulb looks fine too but it won't work
I removed the rear panel to dynamat the thing but now the 3rd brake light won't work :wtc:
Old Sep 19, 2007 | 05:37 AM
Type X's Avatar
Default Re: 3rd Brake light (kroze)
Check to make sure the harness is properly clipped in.
Mine came loose a while back on my si ( with the spoiler brake light )
i THINK its the same harness just routed differently on the EX/LX/DX etc
Old Sep 19, 2007 | 12:25 PM
kroze's Avatar
it's on properly, i even went ahead and took just the bulb assembly out and plug it directly to the harness.
Old Sep 19, 2007 | 12:32 PM
Type X's Avatar
Default Re: (kroze)
did you put a test light to the wiring to make sure its getting power?
if it is you might just have a bad harness ?
if its not that recheck the fuses.... probably missed one.
Old Sep 19, 2007 | 04:15 PM
kroze's Avatar
Default Re: (Type X)
now i gotta go and buy a test light
figured i'm going to try and get a new bulb first.
crxguy406
May 29, 2015 05:38 AM
HA0LEFIED
Nov 28, 2008 12:55 PM
LudeJdm
Aug 16, 2006 08:09 PM
InLimbo87
Oct 25, 2005 08:12 PM
