Little help with a boosted teg
Old Sep 18, 2007 | 10:47 PM
cooltron's Avatar
Default Little help with a boosted teg
Maybe you guys can help answer some questions i got. I put on my new setup and we wanted to see if the turbo would spool or not. All i put on was the manifold, turbo, and wastegate, with no vaccum hoses connected. Technically it should boost a lil bit, like 1 or 2 pounds right? I rev it a lil bit and i can see the turbine spin a lil, but it wont spool yet. I dont know if my wastegate is broken or not either, i think i might just connect the hoses and see if my wastegate really needs to be connected in order to get spool, but i just always thought if you have at least some exhaust hitting it, that it should spool up. any thoughts?
Old Sep 18, 2007 | 11:08 PM
lambertincorp's Avatar
Default Re: Little help with a boosted teg (cooltron)
put it all the way together than try patience and u will be rewarded good luck
Old Sep 19, 2007 | 12:45 PM
cooltron's Avatar
Default Re: Little help with a boosted teg (lambertincorp)
im gonna try putting everything the way it was on my old setup, but while i try that, any other comments from anyone else?
Old Sep 19, 2007 | 12:59 PM
tegman23's Avatar
^^X2
Put it all together than try....ive learned these kinda of things over the years...you wouldnt put a motor half way together and try to start it would you?
namewasdallas
Apr 7, 2010 08:27 AM
crucian
Dec 3, 2006 11:05 AM
slowteg550
Jun 8, 2006 09:00 PM
blumeany
Nov 14, 2003 09:44 AM
AbaZ
Jan 9, 2002 11:05 AM
