eg coin pocket
just ordered coin pocket from jdmland.com. have no clue or idea what to do. could some of you show me(pictures step by step)how to do?
Pry the three switch panel using a flathead screwdriver. Remove the dimmer switch from the plastic "cage" and tuck the switch in the hole. Install the coin pocket, and wallah!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Pry the three switch panel using a flathead screwdriver. Remove the dimmer switch from the plastic "cage" and tuck the switch in the hole. Install the coin pocket, and wallah!</TD></TR></TABLE>
thanks, pictures would be so nice. but i kind of get the idea. thanks anyway.
Oh, you'll need to unplug the dimmer switch in order to remove it from the "cage". Then when you tuck it back, plug in the dimmer switch. Without the dimmer switch, your dash lights won't work. That's why you need to keep it tucked away.
danomatic93
52
Nov 16, 2018 02:53 PM
