Oil light flashing Found out why...
Old Sep 18, 2007 | 07:41 PM
MOE@Hyper16Valve's Avatar
Default Oil light flashing Found out why...
Well i just did a motor build and the oil light started to flash,Well i looked around on Honda-tech and did'nt find to much so i did all the above first i changed the sending unit thinking it could be clogged from just having the motor rebuilt thinkin maybe some metal shaving or some honda bond, So i put a new sending unit The same thing it still flashed not right away but after awhile like warm up Thought the oil pump was bad But it was a brand new one well after some checking of the wiring i found out that theres a INTEGRATED CONTROL unit which is part of the fuse box well that was the problem the unit had a short...
So if anyone has this type of problem you can check that out before you go out and buy a new oil pump...
Found out it can happen from peeps trying to hook up alarms when the alarm shops look for a HOT source to hook up the alarm or stero stuff...
Well i'll post up some pics later just wanted to give some peeps a heads up if they didnt know what it is or if anyone ever has the same problem...
PEACE...
MOE@HYPER16VALVE...
Old Sep 18, 2007 | 09:42 PM
kcjohnnyboy's Avatar
good info. thanks, i will keep that in mind
Old Sep 21, 2007 | 07:04 PM
Default Re: (kcjohnnyboy)
PICs will be up soon...
Old Sep 22, 2007 | 06:01 AM
The_Undertaker's Avatar
75.168.105.221
It could have also meant oil starvation. Either not at full mark on dipstick or a leak somewhere and sufficient oil leaking when driving. There is an oil pressure sending unit switch one above oil filter and one on vtec heads. When low pressure light is on warning low oil.
Old Sep 22, 2007 | 08:55 AM
~sp33~'s Avatar
EFB055
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">It could have also meant oil starvation. Either not at full mark on dipstick or a leak somewhere and sufficient oil leaking when driving. There is an oil pressure sending unit switch one above oil filter and one on vtec heads. When low pressure light is on warning low oil.</TD></TR></TABLE>
Old Sep 22, 2007 | 10:09 AM
Default Re: (~sp33~)
***OIL LIGHT is Flashing ON not Constantly ON**
All the stuff mentioned was taken in by consideration before the motor was assembled. My motor work knowledge and assembly knowledge speaks for itself from all the customers i have had in the past and presently. I used and searched for similar situations here on H-T and results are all the same. "change oil pump, change pressure sending unit/s, and all necessary things that will cause oil to flow, read, or even leak".
What happens to the situation when its all purchased brand spanking new from OEM, OEM Replacement Parts, or even Numerous Automotive Parts stores??
This is just a suggestion its not saying this is the main problem but something to look at. Not all would consider looking into specifics. But you can easily trace back solutions in the Haynes Manual. That manual is where i found out the answer of why the oil light keeps flashing.
Main Fuse Box under driver side Interior example being used is a DA
Part Number
Fuse Box Taken Out and Removed Parts to show location
Integrated Control Unit Located in the back Of Fuse Box
Exposed Integrated Control Unit Board
Top View and Part location of Failure
Burnt Heat Spot on Board Zoomed IN
Burnt Spot Pointed Out Far View
Please Refer to Page 12-28 Chpt 12 Chassis Electrical System On Haynes Manual for Acura Integra (1990-1993) and Chilton Manual for 84-91 Civic/Crx page 6-96 Chassis
Electrical. Its all have to do with wiring.
Thanks for viewing
Modified by MOE@Hyper16Valve at 11:47 AM 9/22/2007
Old Sep 22, 2007 | 10:52 AM
Sorry double post
Modified by MOE@Hyper16Valve at 9:40 PM 9/22/2007
Old Sep 22, 2007 | 08:39 PM
STREETWERKZ's Avatar
finally you give some half-way decent information. but what you described would be a solid oil light, not a flashing light. you are wrong, yet again. what a surprise.
Old Sep 22, 2007 | 08:42 PM
Default Re: (STREETWERKZ)
good looking out on the correction Streetwerkz
Old Sep 22, 2007 | 08:45 PM
EF2_Sedan88's Avatar
Default Re: (MOE@Hyper16Valve)
STREETWERKZ + 1988hondacrxsiR1 = Best Friends 4 life
Old Sep 22, 2007 | 08:48 PM
Default Re: (EF288Gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF288Gsr &raquo;</TD></TR><TR><TD CLASS="quote">STREETWERKZ + 1988hondacrxsiR1 = Best Friends 4 life </TD></TR></TABLE>
he's like a retarded younger brother that should be locked in the basement so nobody see's him.
Old Sep 22, 2007 | 10:34 PM
Just wanted to get some 411 out there It's been a minute from doing write up's and what not...
Big thanks to JKENO112@hyer16valve for the help with him this would not be happening...
Photo skills old school style JKENO112@hyper16valve...
peace
MOE@HYPER16VALVE...
Old Sep 23, 2007 | 07:24 AM
crazykamper's Avatar
could this be the same problem causing an oil light to be on under 1k rpm??? or is this for just random oil light to go on?? thanks!
Old Sep 23, 2007 | 08:47 AM
75.168.105.221
The solid oil pressure light stays on because the person hasn't filled the engine up to full at all. The Flashing oil pressure light blinks or flashes because it is warning the driver that oil pressure is okay when driving fine. A flash comes on when you are beating on it because there is no oil for the oil pump to feed off in the oil pan. Its like a straw and a cup of water you drink calm. But when you use vacuum as the oil pump it sucks all the water rapidly. The light flashes because the original creator is beating on it not realizing that he has low oil pressure level. And Streetwerkz + 1988hondacrxsiR1= Best Friends 4 life. I dunno lets see if we can make it until 2010. Good luck MOE@Hyper16Valve
Old Sep 23, 2007 | 09:46 AM
Did you read the flashing light comes on for the short in the relay part that i show the oil light that comes on and stays on thats not the problem here if you want to start your own thread about the oil light that just stays on then do so...
My thread is to inform peeps with a flashing oil light flashing means there is a short in the wiring...
Now if the oil light just stays on then you would do the following check the oil level,check oil pressure,check or even change oil pump...
Now i just did a rebuild and all that was done fresh oil,fresh oil filter,fresh oil pump,fresh oil pressure sending unit and the problem is the oil light started to flash or blink and the problem was the intergarted control unit and nothing else...
Old Sep 23, 2007 | 11:45 AM
Chiovnidca's Avatar
Default Re: Oil light flashing Found out why... (MOE@Hyper16Valve)
Glad you found the problem. Problems in the integrated control unit can be difficult to diagnose.
Just wanted to note that ef civics dont have the oil light wired through the icu.
Old Sep 23, 2007 | 11:53 AM
Default Re: Oil light flashing Found out why... (Chiovnidca)
Its in the wiring diagram you can check this out and also the i posted as a EXAMPLE the DA integra fuse box...
need to read alittle more it's all good thanks for viewing...
Old Sep 23, 2007 | 01:31 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOE@Hyper16Valve &raquo;</TD></TR><TR><TD CLASS="quote">Its in the wiring diagram you can check this out and also the i posted as a EXAMPLE the DA integra fuse box...
need to read alittle more it's all good thanks for viewing...</TD></TR></TABLE>
This is the ef forum, thanks for visiting, asshat
Old Sep 23, 2007 | 03:34 PM
Default Re: Oil light flashing Found out why... (Boosted Chemist)
Asshat if you read it i posted it as a a example...
And since you viewed and posted that means i must of got your attention if you dont like what you read or seen then dont post on it and dont let the door hit you on the way out...
Also no need for name callin just repeating what you called me...
Old Aug 24, 2018 | 09:03 AM
lorri miller's Avatar
PEACE...
MOE@HYPER16VALVE...
thank you for helping me solve the problem of my oil light. It made so much sense because the alarm on my car doesn't work due to a short. I had a friend who does alarm and other electronic system installs on anything with wheels, tell me the dealership needs to take out the alarm because of its integration with other systems in the car. Fixing this problem might fix the alarm issue as well. My car is amazing. It's mostly original parts so it could be the pump or any number of parts along the system. Your suggestion is an easy place go start and just might fix two problems. Again thanks for giving me a place to start.
ek_b16
Sep 10, 2011 04:48 PM
junior_tm
Jul 1, 2009 11:22 AM
clh308
Dec 17, 2008 05:56 PM
hondaracing1
Mar 27, 2004 05:38 PM
hondaracing1
Mar 27, 2004 01:46 PM
