Atomosphere Pressure Sensor
Old Jun 17, 2002 | 12:35 PM
Civic89's Avatar
Default Atomosphere Pressure Sensor
I have code 13 (atomosphere pressure sensor) and 3 (map sensor) on my ecu. I know where the map sensor is but the manual show's nothing on the atmosphere pressure sensor. Does anyone know where it is?
Old Jun 17, 2002 | 12:37 PM
Urban Business
Guest
Posts: n/a
Default Re: Atomosphere Pressure Sensor (Civic89)
i belive the pressure sensor is built into the map sensor
Old Jun 17, 2002 | 01:00 PM
Civic89's Avatar
Default Re: Atomosphere Pressure Sensor (TorteX)
I think you might be right. There's 2 connectors on the map sensor. Any one else have any info?
Old Jun 17, 2002 | 01:07 PM
ULTRA911's Avatar
I think the PA (Atmospheric Pressure) sensor is located inside the car, passenger side, near the side vents. You know how the Main Relay is located on the driver side, the PA sensor is located at the same place, but on the passenger side.
Old Jun 17, 2002 | 01:10 PM
Perfectionist's Avatar
In the 4th gen, it's located on the passenger side right side panel, just above the plastic. The diagnostic connector is there, too. On later gens, the PA sensor is inside the ECU.
Old Jun 17, 2002 | 01:11 PM
allmotorEG-SI's Avatar
Default Re: Atomosphere Pressure Sensor (ULTRA911)
yeah i read somewhere that its right by that little plug on the passsenger side behind the plastic stuff.
Old Jun 17, 2002 | 01:13 PM
Urban Business
Guest
Posts: n/a
Default Re: Atomosphere Pressure Sensor (CAMAROCRUSHER)
:shrugs:
Old Jun 17, 2002 | 01:26 PM
Civic89's Avatar
Default Re: Atomosphere Pressure Sensor (Perfectionist)
I have a '89 Civic, is it going to be inside the ecu?
Muckman
Feb 15, 2012 04:59 PM
invisible
34
Mar 16, 2007 07:19 PM
Grandhustleman86
Mar 6, 2007 04:34 AM
-JSpecEk*9-
22
Jun 8, 2006 02:26 PM
Cm91h22a
Apr 16, 2002 12:38 AM
