what is to high of a compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bswain22 »</TD></TR><TR><TD CLASS="quote">Is 13.1 compression to high for ls/vtec?</TD></TR></TABLE>
Question for you....why are you running 13:1 compression?
I think 11:5 Cr is the ideal static ratio since you will be able to tune on pump gas and still run a big cam without running into detonation or pulling tons of timing. I dont know why people think they need to run crazy *** CR in order to make decent power..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 »</TD></TR><TR><TD CLASS="quote">I think 11:5 Cr is the ideal static ratio since you will be able to tune on pump gas and still run a big cam without running into detonation or pulling tons of timing. I dont know why people think they need to run crazy *** CR in order to make decent power..</TD></TR></TABLE>
i like this guy. advertised compression is completly different than ur actuall static compression. 11.5:1-12.0:1 should be the max on the east.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teh hatton »</TD></TR><TR><TD CLASS="quote">c16 everday...
and 17:1 !!!!
</TD></TR></TABLE>and 17:1 !!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 »</TD></TR><TR><TD CLASS="quote">I dont know why people think they need to run crazy *** CR in order to make decent power.</TD></TR></TABLE>
I hear you on that.
I hear you on that.
You don't need that high of CR.
But yes. You actually CAN run 13.1 CR on 91 pump gas with a good tune. I've seen it done at the shop where my motor is being built.
But seriously, you don't need this.
yea if ur gonna go with a high compression i hope u choose the cams accordingly. 13:1 on 91 aint happening without pulling almost all of the timing out of it. i had an issue with a 12.5:1 setup on 93 lol let alone 13:1 on 91.
Rhymenoceros
15
Apr 15, 2006 03:59 PM
