D-series Head gasket questions
Old Jun 17, 2002 | 12:30 PM
Todd00's Avatar
I said I don't want a title!
Default D-series Head gasket questions
Will all D series head gaskets interchange? And if so, is there one that gives more compression points over the others?
Old Jun 17, 2002 | 12:43 PM
JaeOne3345's Avatar
Default Re: D-series Head gasket questions (Todd00)
d16y8 headgasket is thinnest oem . yes it will interchange.
Old Jun 17, 2002 | 12:48 PM
Todd00's Avatar
Default Re: D-series Head gasket questions (JaeOne3345)
How does the 92-95 Si headgasket compare in the pecking order? FYI--this is for a D16a6 motor.
Old Jun 17, 2002 | 03:40 PM
JDM EX's Avatar
I bought new Greddy Headgasket and it is 2.0 mm thick.. I ask the guy how thick the stock headgasket and it is .5 mm thick.. Boy, I can tell the different because I look at the Greddy HEadgasket and it is so thick... I probably sell it because I think I dont need it anymore... Good Luck
Old Jun 17, 2002 | 03:42 PM
JaeOne3345's Avatar
Default Re: D-series Head gasket questions (JDM EX)
those greddy gaskets r for turbo use. thats why.
d16z6 and y8 r thinnest. just go y8..on hondaautomotiveparts.com the y8 is cheaper anyway
Old Jun 17, 2002 | 03:55 PM
JDM EX's Avatar
That's true.. You right.. That's why I need thick headgasket and so I can crank up the boost...
austincrx
Jun 2, 2007 02:00 PM
sinfulj32
Nov 29, 2005 06:54 AM
gabspeed
20
Mar 14, 2005 11:43 AM
bey
Nov 7, 2002 11:50 PM
flat-blk-HB
13
Oct 9, 2002 07:50 PM
