Indetify This Sensor.
Old Sep 18, 2007 | 05:40 PM
Simmerman's Avatar
Default Indetify This Sensor.
It's right beside the thermostat. Help? If you need more description, Ill try my best.
Old Sep 18, 2007 | 05:43 PM
95ProjectEJ1's Avatar
Default Re: Indetify This Sensor. (Simmerman)
If that is your thermostat housing that is your Thermoswitch (fan switch)
EKCIVIC99's Avatar
you circles the thermo
Old Sep 18, 2007 | 06:07 PM
Simmerman's Avatar
Default Re: Indetify This Sensor. (EKCIVIC99)
The thermo is on the inside of that piece? I'm looking for whatever goes inside what I circled and it has a sensor that connects to it.
I thought the thermostat sensor was under the dizzy?
Old Sep 18, 2007 | 06:19 PM
Correct, your ThermoSTAT is located inside that housing. Where you have circled is where your ThermoSWITCH would go and would connect to your plug (from your harness).
Old Sep 18, 2007 | 06:20 PM
eg8tuner's Avatar
temp sensor for guage is under dizzy fan switching sensor = there
Simmerman's Avatar
Default Re: Indetify This Sensor. (95ProjectEJ1)
OHH ok kool. thanks man.
Old Sep 18, 2007 | 06:21 PM
lollypopking's Avatar
the thing under the distributor is the coolant temp sender that sends a signal to your water temp gauge. The sensor in the housing you are asking about is the temp switch that activates the radiator fan.
Old Sep 18, 2007 | 06:26 PM
Default Re: Indetify This Sensor. (lollypopking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lollypopking &raquo;</TD></TR><TR><TD CLASS="quote">the thing under the distributor is the coolant temp sender that sends a signal to your water temp gauge. The sensor in the housing you are asking about is the temp switch that activates the radiator fan. </TD></TR></TABLE>
aka Thermoswitch.
I tried looking on SLhondaparts.com and for the life of me could not find the part number. I just replaced mine a while ago and thought I kept the bag... Ill look for my receipts
Old Sep 18, 2007 | 06:32 PM
aka Thermoswitch.
Edit: FOUND IT!! 37760-P00-004 Its under , Engine/Sub Cord Clamp
Old Sep 18, 2007 | 06:37 PM
Simmerman's Avatar
Thanks man.
Old Sep 18, 2007 | 06:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simmerman &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man. </TD></TR></TABLE>
NP, that was for the 92-95, but you can check the 96-00 also. From what I have been told its all the same number GL
Old Sep 18, 2007 | 07:05 PM
THEDirtyDseriesWOOT's Avatar
that is the sensor that shows coolant temp to the cu AND THE ECU TURNS the fan on ...
the small plug under the dizzy is for your guage cluster and does nothing but send signals to the cluster.. trust me i know i did a rhd swap and had to wire all the guages sensors to the ecu since the harness was a big pos
jemo1
Jun 5, 2013 05:55 PM
jlowellintegra
Jun 10, 2011 10:18 AM
fv8s
Jul 29, 2010 05:12 AM
whiterex
Feb 28, 2005 02:57 PM
