BB turns over wont start D4 flashing speedo bouncing
Old Sep 18, 2007 | 05:01 PM
importdreamer's Avatar
Default BB turns over wont start D4 flashing speedo bouncing
Following putting in a new engine in the base model 97 prelude, the car started up with the usual white smoke from the new gaskets and what not. It was driven up the road and back and everything was all good. While waiting to for the registration, went to start it. It started up fine. When we put it in reverse (triptronic auto by the way) it died. Tried to start it again and put it in reverse and it died again. Checked all the fuses and the fuel pump and it was all good. Tried to start it a third time and the speedo jumped up in the 120's and bounced around. The park light on the dash was lit but the D4 light flashed as the car tries to turn over but doesn't start. It ran good at first, so what could be the problem?
Old Sep 18, 2007 | 05:11 PM
mgags7's Avatar
It sounds like you have a transmission code, I'm not familiar with how to read AT codes but you should look into that.
Take it from there, if it wasn't for that I would think a bad ground might cause the speedo to bounce like that.
Old Sep 18, 2007 | 05:24 PM
Default Re: (mgags7)
it doesn't throw a code.
Old Sep 18, 2007 | 05:59 PM
Default Re: (importdreamer)
starter wasn't grounded its all good now.
Old Sep 18, 2007 | 06:04 PM
mgags7's Avatar
good find, that ground is crucial
G0crxG0
Nov 9, 2010 12:31 PM
meagainsttheworld
Sep 16, 2007 05:11 PM
Burke
May 10, 2004 09:48 AM
Burke
May 8, 2004 06:12 AM
BigDawwg6969
Oct 5, 2003 10:08 AM
