steering pin problem??
Old Sep 18, 2007 | 04:52 PM
Eibach95Civic's Avatar
Community Builder
Default steering pin problem??
My steering wheel tilts to the left and when i drive with my steering wheel in its normal position i am turning right. Does a pin need to be adjusted to fix this? thanks
Old Sep 18, 2007 | 05:22 PM
Community Builder
Default Re: steering pin problem?? (Eibach95Civic)
anyone
Old Sep 18, 2007 | 05:33 PM
Mr.EM1_EK's Avatar
sounds like you need an alignment
Old Sep 18, 2007 | 05:39 PM
Community Builder
Default Re: steering pin problem?? (Mr.EM1_EK)
i've had an alignment done both my steering wheel did not move, but my car was aligned properly.
Old Sep 20, 2007 | 06:30 AM
Community Builder
b u m p
Old Sep 20, 2007 | 07:44 AM
rmcdaniels's Avatar
Unless the steering wheel or another part of the steering was removed it shouldn't be like that.
You can unbolt the clamp on the pinion on the steering linkage universal joint, pull it off of the pinion, then turn the wheel and put it back on the pinion to get it straight again. It's part #5 on the drawing below (those parts are under your dash). I don't remember if the top or bottom is easier to pop off, but one of them is pretty easy. Remove the bolt all the way out of the clamp to pop the pinion out.
PrettyMuchBoned
17
Apr 28, 2014 12:25 PM
steadysupreme
Mar 23, 2008 01:04 PM
VTEC-LUDE
Jan 7, 2007 06:42 AM
choi830
Oct 30, 2003 05:13 AM
