T1 cam trigger issue.
Old Sep 18, 2007 | 01:27 PM
slvrslepr's Avatar
Default T1 cam trigger issue.
Wired up the T1 cam trigger to the installation instructions specs. Switched the jumpers in the AEM. Changed all the parameters in the calibrations. Go the fire, but there is no signal. logged the TPER2 and Stat Sync and nothing. There is a crank tooth per signal. Double checked all wiring and found nothing. When changing the jumpers around I used the diagram that mase had posted about a year back. What else could I have missed, or overlooked. There is a 12v source to the sensor and it is grounded. Also tried different distances for the cam trigger.
Old Sep 18, 2007 | 01:36 PM
Fitti's Avatar
Default Re: T1 cam trigger issue. (slvrslepr)
call Tony the last time there was an issue with one, he was all over it like a fat kid in a buffet line
Old Sep 18, 2007 | 02:18 PM
Lonnie's Avatar
Default Re: T1 cam trigger issue. (rota92)
Go to his site there are revised instructions there. Strange, because I just wired one up on sun and the car fired right up.
Old Sep 18, 2007 | 02:44 PM
RCautoworks's Avatar
Default Re: T1 cam trigger issue. (Fitti)
Like everyone said call up Tony, he will talk to you for hours trying to figure out the problem.
Old Sep 18, 2007 | 02:47 PM
ShawnR's Avatar
Default Re: T1 cam trigger issue. (Lonnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonnie &raquo;</TD></TR><TR><TD CLASS="quote">Go to his site there are revised instructions there. Strange, because I just wired one up on sun and the car fired right up.</TD></TR></TABLE>
yea we did terrys car not to long ago and it fired right up with the cam trigger give him a call hes a nice guy he wont bite
Old Sep 18, 2007 | 02:49 PM
Jared's Avatar
there are updated instructions
project dc2's Avatar
Default Re: T1 cam trigger issue. (97gsrcoupe)
tony1 = SCAMMER !!!!!!!!!!
EVIDENCE FOUND !!!
oh wait.. no .. tony1= DUAL CAMMER !!!
Old Sep 18, 2007 | 06:11 PM
slvrslepr's Avatar
Attempted to trouble shoot more, but nothing. I know the sensor is picking up a signal because it is reading rpm signal. I'm stumped by this issues. I will eventually figure this one out.
Old Sep 18, 2007 | 06:37 PM
CivicVX94's Avatar
why don't you call Tony like everyone has said? if he designed and manufacturs it I'd be willing to bet he knows how to make it work
Old Sep 18, 2007 | 06:40 PM
tony1's Avatar
Default Re: T1 cam trigger issue. (CivicVX94)
Sorry Shawn, i was out of the shop most of the day, i was doing a promo deal for NHRA, just got back. I'll call you tomorrow and we'll get it figured out.
And guys, Shawn did try to call, talked to him once this morning and i have a message on my desk that he called back, he's not a dummy. lol
Old Sep 18, 2007 | 09:55 PM
slvrslepr's Avatar
Default Re: T1 cam trigger issue. (tony1)
Thank you Tony. I will look forward to your call.
Old Sep 18, 2007 | 11:45 PM
GodFather of Boost's Avatar
make sure the 12v source you used doesnt shut off when cranking. that one had me going crazy. felt like a retart when i found the problem.
Old Sep 19, 2007 | 04:45 AM
JDogg's Avatar
Default Re: T1 cam trigger issue. (GodFather of Boost)
which ems are you using?? if its a 1050 there is a "hall effect power" at one of the pins, use that to power it and make sure to use a sensor ground. sometimes you can get away with using a chassis ground and a normal 12v source, but becasue of the the fairly loose tolerances in the resistors that pull it to 5 volts the signal might not be strong enough. if you dont have the 1050box do like godfather said and double make sure you still have 12v while cranking. i use the power nad sensor grounds at the distributor plug normally.. i cut the plug off the distributor and make a jumper plug to plug the hall sensor into that.
Old Sep 19, 2007 | 05:21 AM
tony1's Avatar
Default Re: T1 cam trigger issue. (JDogg)
If you're getting an rpm signal during cranking, then the power and ground have to be ok. Email me your AEM cal file and let me check it out.
Old Sep 19, 2007 | 09:13 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">If you're getting an rpm signal during cranking, then the power and ground have to be ok. Email me your AEM cal file and let me check it out. </TD></TR></TABLE>
that too
Old Sep 19, 2007 | 11:43 AM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
whats the benefit of running this ignition in your car?? any power gains??
Old Sep 19, 2007 | 11:51 AM
JDogg's Avatar
Default Re: (99hondacura)
if you have an aftermarket ecu that can use the hall effect signal it gives a much more stable and precise cam/crank position signal to the ecu for more accurate fuel and ign timing
Old Sep 19, 2007 | 07:50 PM
slvrslepr's Avatar
The only thing I can conclude from my findings is that the sensor may be bad. I used another aem and the same problem. I checked voltage at the aem to both sensor wires and they were both -4.90 or so. I love how we get to the finish line and we began to cramp up. This is definitely frustrating, but that comes with the territory.
Old Sep 19, 2007 | 08:02 PM
I meant to the m&w box. make sure the power stays on while cranking
Old Sep 19, 2007 | 08:26 PM
slvrslepr's Avatar
It does.
Old Sep 20, 2007 | 08:57 PM
slvrslepr's Avatar
Found the problem. The sensor is bad. Thank you Tony for your help. I guess I will need a new one.
type-GGSR
K Series
Apr 19, 2013 10:16 PM
Catfish4748
Oct 7, 2010 10:22 AM
NOSed_b18b
Feb 22, 2002 05:35 AM
