Garret t3/t4 .50 trim question!?
Old Sep 18, 2007 | 11:54 AM
401tuner's Avatar
Default Garret t3/t4 .50 trim question!?
thinking about picking up a .50 trim for my set up. I was wondering when you guys were fully spooled using this turbo and how much power were you making 10psi and under.
Old Sep 18, 2007 | 01:25 PM
401tuner's Avatar
Default Re: Garret t3/t4 .50 trim question!? (401tuner)
some ones gotta have some info on this, i know there is a lot of you out there running .50 trims
Old Sep 18, 2007 | 03:59 PM
JaredKaragen's Avatar
depends on the AR of the housings.
general "50 trim" egay turbos will hit spool around 4.5K-5K. Sometimes earlier or later; depending on motor.
Old Sep 18, 2007 | 04:43 PM
poop II's Avatar
Default Re: Garret t3/t4 .50 trim question!? (JaredKaragen)
93
The hotside has a greater effect upon spool. Also keep in mind that boost threshold/spoolup is not a constant, but dependant upon gear and load conditions. A .48 turby would probably choke it up top but have a zippy spoolup, a .63 would be just about optimal for a street gsr, and the .82 is better suited to bigger compressors. A stage III wheel is a good match for the 50. Keep in mind that a 50 trim is actually on the small side for a gsr.
93 93/93
Old Sep 18, 2007 | 04:57 PM
1fastEK9's Avatar
Default Re: Garret t3/t4 .50 trim question!? (poop II)
save your $$$ and buy a real turbo, don't spend your $$$ on ebay xpower etc pieces of ****
Old Sep 18, 2007 | 05:17 PM
ek_chris's Avatar
highly dependant on set-up and a/r as well.
I've seen some hit full boost just before or around 4K and i've seen some hit just before 5k. Depends on the setup and load conditions like stated before..
Old Sep 18, 2007 | 05:38 PM
401tuner's Avatar
Default Re: (ek_chris)
Modified by 401tuner at 2:29 PM 9/25/2007
Old Sep 25, 2007 | 09:49 AM
ekb18-t's Avatar
you could get the 57 trim with the .48 ar and spool should not be to bad i am runnin one on a stock ls.....what motor do u have?
Old Sep 25, 2007 | 10:30 AM
401tuner's Avatar
Default Re: (ekb18-t)
98 gsr daily driver
Old Sep 25, 2007 | 12:16 PM
inthad's Avatar
Default Re: (401tuner)
what if its a .50 trim with .50 a/r. What about that? Whats the spool on that. And what kind of power can I make only boosting 7lbs.
Old Sep 25, 2007 | 01:49 PM
401tuner's Avatar
Default Re: (inthad)
on my set up i will be running a t3/t4 .50 trim a/r .63
the.hamburglar
Aug 17, 2007 04:21 AM
401tuner
May 17, 2007 05:09 PM
gsrobdi
Oct 4, 2005 09:22 PM
DA6righthand
May 28, 2004 11:20 PM
Purelude
Sep 13, 2001 01:20 PM
