oil capacity of a b16
Old Sep 18, 2007 | 11:45 AM
99fbpem1's Avatar
Default oil capacity of a b16
Before I get yelled at to "check your manual" I don't have a manual, I am pretty sure it is 4.5 quarts. But this is the first time i have changed the oil in my b16. Thanks
Old Sep 18, 2007 | 11:58 AM
egsleepercivic's Avatar
start with 4 then check your dipstick, dipstick
gl
Old Sep 18, 2007 | 12:01 PM
philosofy1's Avatar
Default Re: oil capacity of a b16 (95civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Before I get yelled at to "check your manual" I don't have a manual, I am pretty sure it is 4.5 quarts. But this is the first time i have changed the oil in my b16. Thanks </TD></TR></TABLE>
i just use 4qt. haven't had any problems yet.
Old Sep 18, 2007 | 12:02 PM
crazyguy's Avatar
Default Re: (egsleepercivic)
manual suggests 4 qts
Old Sep 18, 2007 | 12:08 PM
99fbpem1's Avatar
Default Re: (crazyguy)
4 qts it is, too bad i bought 5, o well. only have to buy 3 next time. just to make sure there aren't any problems with switching to fully synthetic from dyno oil correct?
Old Sep 18, 2007 | 12:23 PM
99fbpem1's Avatar
Default Re: (95civicdx)
i just drained my oil out of the pan and into a jug to recycle when i noticed there is a washer at the bottom of the drain pan. When i took the drain plug out it fell into the oil, i guess there was a washer on it. I never had a washer on my d series, should i drain my oil and put the washer back on? help
Old Sep 18, 2007 | 12:27 PM
jeremyyeahh's Avatar
i have a 2000 si man. it took four and a half.
Murk 'EM's Avatar
you can either fish it out or get a new one
Old Sep 18, 2007 | 12:29 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx &raquo;</TD></TR><TR><TD CLASS="quote">i just drained my oil out of the pan and into a jug to recycle when i noticed there is a washer at the bottom of the drain pan. When i took the drain plug out it fell into the oil, i guess there was a washer on it. I never had a washer on my d series, should i drain my oil and put the washer back on? help</TD></TR></TABLE>
yes a new drain washer is required each time for oil change service and u can get the washer from your local honda dealership and it can not or better not to reuse it
Old Sep 18, 2007 | 12:31 PM
99fbpem1's Avatar
my problem is i just put the oil back into the car, I didn't know that there was a drain washer, my d series didn't have one or was i just missing it the entire time i had my car?
Old Sep 18, 2007 | 12:35 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx &raquo;</TD></TR><TR><TD CLASS="quote">my problem is i just put the oil back into the car, I didn't know that there was a drain washer, my d series didn't have one or was i just missing it the entire time i had my car?</TD></TR></TABLE>
u missed it the entire time but i think the main purpose of that darin washer is to seal the drain plug tight, so no oil will be dripping from the darin plug..my honda dealership gave me couple of those for free and the oil drain plug washer is also the manual tranny oil drain and refill washers
BEE1's Avatar
4.2 qts of 5w30
Old Sep 18, 2007 | 12:36 PM
philosofy1's Avatar
you can dump o your oil in a clean container, then add the washer to the bolt, then add the oil again. you can also leave it the way it is now and add the washer later on the next oil change.
the only thing is, whether you leave it like it is now or reuse the washer it will leak, not much, but enough to stain your drive way. next time you are at the dealer, get one. they are like $.02 (if that).
Old Sep 18, 2007 | 12:38 PM
99fbpem1's Avatar
would it be better to reuse the old one or not use one? i won't be able to get to a honda dealership for atleast a couple of days, i'm gonna have to be quick to take out the plug, plug up the whole with a finger and then put the plug back in. I guess it's good that i bought an extra quart. live and learn i guess
Old Sep 18, 2007 | 12:40 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx &raquo;</TD></TR><TR><TD CLASS="quote">would it be better to reuse the old one or not use one? i won't be able to get to a honda dealership for atleast a couple of days, i'm gonna have to be quick to take out the plug, plug up the whole with a finger and then put the plug back in. I guess it's good that i bought an extra quart. live and learn i guess</TD></TR></TABLE>i really dont recommend to reuse it cause it is already been smashed..u should have seen the new ones to compare..but if u cant get to dealership any sooner...u can try to put it back on and resue it and keep an eye on the drain plug
Old Sep 18, 2007 | 12:42 PM
99fbpem1's Avatar
i think i'll just do it on my next oil change, that's odd my d series never leaked.
Old Sep 18, 2007 | 12:53 PM
audiko4's Avatar
Default Re: (BEE1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEE1 &raquo;</TD></TR><TR><TD CLASS="quote">4.2 qts of 5w30</TD></TR></TABLE>
Sounds right to me
EK_B
Oct 28, 2007 02:39 PM
quilter@atlanticbb.net
10
Jul 20, 2007 12:06 AM
bseries_ben
Apr 12, 2007 01:58 PM
Suck my DX
Jun 12, 2005 02:09 PM
RCautoworks
Dec 31, 2002 10:42 PM
