open door....light comes on ..... beep, beep, beep?
Old Sep 18, 2007 | 11:26 AM
JDMgareth's Avatar
Default open door....light comes on ..... beep, beep, beep?
Don't know what the technical name for this common occurance is but when I open my drivers side door, my dome light does not come on. Also, I notice in 95 preludes a sound goes beep beep when the door is open and the keys in ignition?
Is this true in 92 SI?
Biggest question is...where is the part that initiates this sequence...because I want to fix it
Old Sep 18, 2007 | 11:39 AM
baselude's Avatar
Default Re: open door....light comes on ..... beep, beep, beep? (JDMgareth)
yah i have a 92 s and it beeps cuz my ignition sticks, but i just push on it and it pops out
Old Sep 18, 2007 | 11:42 AM
MLBZ521's Avatar
There's a sensor on both doors. It's like a push lever, when the door closes it gets pushed back, and when it's open the spring pushing it out.
Look, it's not that hard to find..
Just a screw or two, take it off, carefully take it apart, and clean the metal inside with a wire brush or sharp tool..
My passenger side one didn't work because it was old and corrosive, so it wasn't getting a good connection.
Old Sep 18, 2007 | 12:53 PM
Honda4Life.'s Avatar
#19 in this link is what your looking for.
http://www.slhondaparts.com/br...=true
Mike (H4L)
Old Sep 18, 2007 | 01:38 PM
JDMgareth's Avatar
Default Re: open door....light comes on ..... beep, beep, beep? (Honda4Life.)
For that part # it doesnt have a line to show where its at in the car but if i were to guess....
its not near the hinge, its near where the open part of the door connects. not in the door, but in the rear fender area right near where the door swings too? k.
so...will a 92 SI make a beeping noise when doors open and keys in? I have never heard it before and im kind of excited...
Old Sep 18, 2007 | 02:55 PM
russlan44's Avatar
my beep beep noice is on when i take out the key, theres like something stuck in ignition that i have to pop it everytime i take out a key, hard to explain but im tired of poping the little metal thing inside ignition
Old Sep 18, 2007 | 03:43 PM
Default Re: open door....light comes on ..... beep, beep, beep? (russlan44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMgareth &raquo;</TD></TR><TR><TD CLASS="quote">For that part # it doesnt have a line to show where its at in the car but if i were to guess....
Trust me the is the correst part.
Why should ya trust me, well I am a parts guy for Honda. i may know what I am talking about.
Just because the pic is bad doesn't mean it isn't what ya need.
Mike (H4L)
Old Sep 18, 2007 | 10:42 PM
TylerC161's Avatar
I think its beep beep beep beep beep isint it?
the beeps changed that year, its a different beep part.
Old Sep 19, 2007 | 04:55 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote">my beep beep noice is on when i take out the key, theres like something stuck in ignition that i have to pop it everytime i take out a key, hard to explain but im tired of poping the little metal thing inside ignition</TD></TR></TABLE>
That happens with overused ign switches over time. Stop driving so much
You definitely have a bad door sensor, honda4life is right.
Old Sep 19, 2007 | 10:54 AM
JDMgareth's Avatar
Default Re: open door....light comes on ..... beep, beep, beep? (mgags7)
nono, i didnt say you were wrong about the part. what im saying, is that in that picture it doesnt show where the part is located in the car.
Because i want to try and fix it before i replace it.
most of the other parts in the illustration have lines to show where they are; that one doesn't.
Old Sep 19, 2007 | 07:33 PM
dark_rican's Avatar
The part is located in the door jam. Open your door and you'll see it near the latch. If you're referring to the beeping/chime when the keys are in the ignition while the car is off and the door is open, 92 Si has that. My 94 S never chimed and neither did my ex's 94 S.
Old Sep 20, 2007 | 07:16 AM
mikemjohnson's Avatar
My drivers door fails to engage the dome light but passenger works, ill look into it doing what you guys said and get back to ya'll
though im a 5g, and most of you guys are 4g, ill see how similar it is
Old Sep 20, 2007 | 07:42 AM
mgags7's Avatar
If the S model didn't come with that feature I'd be surprised, it seems like such a simple thing, why would Honda leave that out?
Anyways, I bet all that switch does is ground a single wire that runs to it. Try taking it off and cleaning it well, and check the wire/connector
Butters54
Nov 19, 2017 07:22 PM
JdM_Eg6_SiiR
May 8, 2009 12:59 AM
LudeJdm
Feb 21, 2007 06:01 PM
blinger
Oct 9, 2006 01:53 PM
spencedogg
Mar 7, 2003 11:33 PM
