valve adjustments
Old Jun 17, 2002 | 11:08 AM
743power's Avatar
Default valve adjustments
Does anyone here have an idea of the common price for a valve adjustment? I'm about due and I want to try to do it before I get rid of my car.
Old Jun 17, 2002 | 11:13 AM
Spade's Avatar
Default Re: valve adjustments (743teg)
100+
Just buy the tool and do it yourself.
Old Jun 17, 2002 | 04:02 PM
Chiovnidca's Avatar
$73
Old Jun 18, 2002 | 03:37 AM
EE_Chris's Avatar
Default Re: valve adjustments (Spade)
Does the tool really make the job THAT much easier than using a 10mm wrech and a flat head screwdriver....always seems to work for me?
Old Jun 18, 2002 | 07:33 AM
Spade's Avatar
Default Re: valve adjustments (EE_Chris)
On a DOHC yes......not on a SOHC.....very easy on a SOHC.
Old Jun 18, 2002 | 08:22 AM
b17gsr's Avatar
First time I got mine ajdusted at the local Acura dealership. Cost 1 hour labour + tax ~80$ cdn.
Second time I found a Snap On truck parked in a parking lot for his lunch break. Walked over and asked if he minded selling me a tool while on his lunch break. So I ordered the part and picked it up a few days later. Cost ~70S cdn.
I've used it 4-5 times already, paid for itself a long time ago! BTW my B17A and D16 (90 Si) both use 10mm socket, where as the ZC 12mm. So find out what you need before you buy it.
Old Jun 18, 2002 | 08:32 AM
96_GSR's Avatar
Default Re: valve adjustments (b17gsr)
$85 at a Honda dealership. I wouldn't use a screwdriver to check the clearance. Just a buy $2 feeler gauge.
Old Jun 18, 2002 | 08:40 AM
EE_Chris's Avatar
Default Re: valve adjustments (96_GSR)
I can only assume the screwdriver comment was for me. Yeah, I know....I'm actually kinda cracking up at the thought.
I have a 99 Cx [D16Y7] and when I do my valves, I just use a 10mm and screwdriver...along with the appropriate feeler gauges to check clearances. The screwdriver was for ADJUSTING the clearances.
Old Jun 18, 2002 | 09:31 AM
filetofit
Guest
Posts: n/a
Clamp a 10mm deep socket in a pair of vise grip pliers and stick a screwdriver down the center of the socket, works great, cost = $0.00
Old Jun 18, 2002 | 03:15 PM
MikeSarr_GSR's Avatar
Default Re: valve adjustments (filetofit)
Do this!
learn how to do it yourself! the dealerships only let the engine
cool about 45 minutes and then adjust them. This can make
for non-ideal setup. When I do mine, I let the car sit overnight
and then do it before I go to work. I do them about every
5000 miles since I am on larger cams and run the car hard.
10mm socket with extension and old school ratchet, flat
head and feelers. Remove plugs... 1,3,4,2... check em...
.007
.008
perfect.
Close...
Done.
I love the feeling of solid VTEC in the morning...
Powered by VTEC
16
Jan 20, 2008 03:47 PM
codyb13
Apr 26, 2005 09:18 AM
vulgar_si
Nov 18, 2004 05:31 AM
RuskeR
May 16, 2003 10:39 AM
Bbasso
Nov 18, 2002 01:51 PM
