LM1 with hindata S200
Old Sep 17, 2007 | 11:19 PM
gsrt's Avatar
Default LM1 with hindata S200
do you know how to connect innovate LM1 to S200? thanks
in hondata for PLX
-Red wire Power cables for the PLX wideband - connect to switched power in the fuse box
-Black Ground - Attach to solid chassis ground
-White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU)
-Gray 0-1V Output for narrowband - connect to white wire from stock O2 plug per instructions below
but LM1 have 5 wire color. red, black, white, gray and yellow. anyone know thanks
Old Sep 17, 2007 | 11:34 PM
mtber's Avatar
Default Re: LM1 with hindata S200 (gsrt)
Go to the LM1 website, download the instructions & simply wire the 0-5v output to your ecu for datalogging purposes.
b16bri
Oct 8, 2021 03:20 AM
EF9ZC
Apr 1, 2006 07:13 PM
raceACCORDingly
Jan 7, 2003 05:31 PM
Teg4e
May 8, 2002 03:49 AM
maxim
Jan 19, 2002 06:00 PM
