3-way and 2-way components. whats the difference?
A 3 way component set has 3 speakers
Tweeter
Mid-range
Mid-bass
A 2way system set has 2 speakers
Tweeter
Mid-range
The 3 way spits the frequencies up so each speaker plays a smaller range of frequencies. The idea is a smaller range will be more accurate as the speaker can be more specifically designed to play a small set of frequencies.
That does not mean 3-ways are better then 2-ways. Listen to both and decide which you prefer.
Tweeter
Mid-range
Mid-bass
Tweeter
Mid-range
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I used q-logic kick pannels with a lil modds to them and used the door for the midbass driver. This was in a teg and the sound was so clean that you would of thought there was a sub in the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater »</TD></TR><TR><TD CLASS="quote">I used q-logic kick pannels with a lil modds to them and used the door for the midbass driver. This was in a teg and the sound was so clean that you would of thought there was a sub in the car. </TD></TR></TABLE>
so let me get this straight....you'd put the mid-range speaker in your front door and the mid-bass and tweeter would be in the q-logic kick panels.
is there a cheaper route to install the 3 way components in the fronts, cheaper than the q-logic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Utensils »</TD></TR><TR><TD CLASS="quote">
is there a cheaper route to install the 3 way components in the fronts, cheaper than the q-logic?</TD></TR></TABLE>
Almost right, except its the mid-bass that goes in the door, and the mid-range in the kick panel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moridin2004 »</TD></TR><TR><TD CLASS="quote">
Almost right, except its the mid-bass that goes in the door, and the mid-range in the kick panel.</TD></TR></TABLE>
3-ways and cheap are not to be used toghter
imadigitalgod
Audio / Security / Video
12
Nov 13, 2009 01:58 PM
bassisliffe
Jul 22, 2004 12:22 PM
