mini me?
Old Jun 17, 2002 | 10:04 AM
projectcrx's Avatar
Default mini me?
im using the y6 head and intkae mani can i use the 90-91integra injectors intead of the 88-91 crx ones because i can pick a set up really cheap thanks
Old Jun 17, 2002 | 10:07 AM
xpurespeedx's Avatar
Default Re: mini me? (projectcrx)
As far as I know all the injectors flow at the same rate.
Old Jun 17, 2002 | 10:26 AM
projectcrx's Avatar
Default Re: mini me? (xpurespeedx)
can anyone please confirm this can i also use the 90-91 dist insted of the 88-91 crx si one???
Old Jun 17, 2002 | 10:30 AM
markedOO1's Avatar
the b series dizzy's not gonna bolt up... and yeah, all the b/d injectors flow the same...
Old Jun 17, 2002 | 11:24 AM
projectcrx's Avatar
Default Re: mini me? (marked001)
but i thought that you cant use the 92-95 civic injectors when doing the dpfi-mpfi swap?so then how do they all flow the same?
Old Jun 17, 2002 | 11:30 AM
RyanR's Avatar
You can't use the 92-95 injectors cause they're saturated, you need peak and hold from a 88-91 Civic/CRX. 92+ doesn't use the injector resistor box so the injectors aren't too swift when you use them on a obd0 car.
Old Jun 17, 2002 | 12:56 PM
d357r0y's Avatar
Default Re: mini me? (RyanR)
not to mention the connectors are different
Old Jun 17, 2002 | 04:52 PM
projectcrx's Avatar
Default Re: mini me? (d357r0y)
so can i use the 90-91 integra injectors when doing the dpfi-mpfi swap??
Old Jun 17, 2002 | 04:56 PM
Trinity's Avatar
i swear to god i'm gonna go A WOL if i see another mini me post. please for the love of god type mini me int he search bar and LOOK UP this info, its been posted a million times what you can use and can't use. lik right here https://honda-tech.com/zerothread?id=209474
Old Jun 17, 2002 | 06:33 PM
projectcrx's Avatar
Default Re: mini me? (Trinity)
thanks buddy but that says nothing about what injectors i can use so can someone please tell me if i can use the 90-91 integra injectors?
Old Jun 18, 2002 | 05:12 AM
Trinity's Avatar
well I KNOW that isn't the only mini me post around. like isaid search for your info
no nevermind here , why don't you use the injectors that COMES with the intake manifold, and if it didn't come with injectors why don't you try using those that go with that head
Old Jun 18, 2002 | 11:20 AM
projectcrx's Avatar
becuasde if you read above you cant use the 92-95 injectors
Old Jun 18, 2002 | 05:49 PM
projectcrx's Avatar
come on can someone tell me if i can use the 90 -91 teg injectors for the dpfi-mpfi swap and then a mini me
Old Jun 18, 2002 | 05:59 PM
3RROR404's Avatar
The answer is yes. If your doing DPFI to MPFI then you've already acquired the injector wiring harness and resistor box, Now you just need the injectors, and MPFI ecu and some wiring. GL
96civic808
Apr 22, 2010 12:23 PM
B16A CRX
Mar 16, 2007 12:23 PM
XzzYzzX
May 17, 2003 05:22 PM
VTECVillain
Mar 31, 2002 09:23 PM
DelsolVtec18
Oct 5, 2001 03:56 PM
