Balance shafts
OK... so i think my balance shafts are not adjusted properly. My engine shakes at certain RPMs and then goes away after certain RPMs. How can i see if they are adjusted properly and how do i adjust them. Only serious replies cause i don't feel like arguing with the usual gang
Guest
Posts: n/a
theres a plug on the back of the block by the balance shaft for the oil pump. take that 12mm bolt out..it has a crusher washer on it. stick a screw driver in it as you turn it and eventually the screw driver will go all the way in. once it is in the all your makrs should line up if they dont then there off...
EGmikeH22
Jul 31, 2005 04:53 PM
poison
Jul 1, 2003 04:31 PM
gulftools
Mar 5, 2003 02:12 AM
