Rough Transmission
Old Sep 17, 2007 | 04:39 PM
Mike1995HondaPrelude's Avatar
Default Rough Transmission
My stick rumbles going into fifth gear. I was told it could be a clutch problem. Someone else told me in could be the sycros. Are those likely the sources of the problem?
Old Sep 17, 2007 | 08:23 PM
Default Re: Rough Transmission (Mike1995HondaPrelude)
up
Old Sep 17, 2007 | 08:25 PM
dagle's Avatar
is it a grind noise? but yeah, if u have rumbling in ur shifter its usually clutch/tranny =P
Old Sep 17, 2007 | 08:46 PM
preludefien
Guest
Posts: n/a
Default Re: Rough Transmission (dagle)
i would think that it was your sycros
Old Sep 17, 2007 | 08:53 PM
viper_boy403's Avatar
what year is the car? 5th gens have a very common problem with a misaligned shift fork which causes a 5th gear grind. I had it, changed my tranny fluid, and it's gone now
Old Sep 17, 2007 | 10:05 PM
vteclude07's Avatar
Default Re: (viper_boy403)
in the morning ill take a picture of what his problem is and post it on here
Old Sep 18, 2007 | 05:22 PM
Default Re: (vteclude07)
thanks its a 4th gen though 1995.
Old Sep 18, 2007 | 06:00 PM
hondatunedbboy's Avatar
Default Re: (Mike1995HondaPrelude)
I think it was in the production of all H22a4's under a hood. 5th gear synchro goes out. I've heard of a cryogenic process to keep it from happening. But I am sure that the synchros you can buy from a dealer are up to specifications to prevent further wear.
Old Sep 18, 2007 | 06:07 PM
Default Re: (hondatunedbboy)
isn't the repair pricey?
Old Sep 18, 2007 | 06:21 PM
vinuneuro's Avatar
There's a TSB for this problem, 92-01. You might want to try changing the trans fluid to the new Honda mtf first.
http://members.shaw.ca/FifthGe...d.pdf
bboyfreeze
Mar 26, 2007 06:41 AM
JDM B16A
11
Mar 18, 2006 03:44 PM
korndog
Jan 3, 2005 08:28 PM
BLK99VTECR
Oct 6, 2004 01:01 PM
ragerized
Jul 11, 2004 03:53 PM
