Revving problem
Old Sep 17, 2007 | 03:49 PM
carnage601's Avatar
Default Revving problem
I have a 89 CRX Si with a D16y8 mini me swap. but i have a problem it will only let the engine Rev. up to 3500 RPM. If anyone could give me some info it would be great. Thanks
Old Sep 17, 2007 | 03:56 PM
denraweb's Avatar
Default Re: Revving problem (carnage601)
Do you have a CEL? Maybe the ECU is in limp mode (won't let the engine rev past a certain point to protect the engine from detonation)?
Old Sep 17, 2007 | 04:11 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Revving problem (denraweb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denraweb &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a CEL? Maybe the ECU is in limp mode (won't let the engine rev past a certain point to protect the engine from detonation)?</TD></TR></TABLE>
Yes, that is limp mode.
OP, you have a CEL (or several) that need to be cleared up. You will need to count the number of times the ECU light blinks (long blink=10, short blink=1), then use the link below to determine what the problem is.
Here they are: https://honda-tech.com/zerothread/1710584
Old Sep 17, 2007 | 04:33 PM
carnage601's Avatar
Default Re: Revving problem (wiZCo)
Hey thanks guys. that helps alot
Old Sep 17, 2007 | 04:54 PM
gp70hs's Avatar
I strongly suspect you have a problem with the tdc sensor on the distributor. Their are several possibilities, but the most likely is that it's wired up incorrectly.
Following that, it could be either the distributor, or it could be the ecu, with the most weight going to the distributor.
שלבי עבדו
Oct 30, 2016 07:14 AM
OnceIwasMuffin
May 18, 2015 02:17 AM
turboteg90
Jun 24, 2008 11:52 PM
Quade
Nov 24, 2005 12:15 PM
Fatty_1775
Jul 10, 2003 10:14 AM
