Installing a remote starter (2006 Civic DX 5speed)
Old Sep 16, 2007 | 07:23 PM
kroze's Avatar
Default Installing a remote starter (2006 Civic DX 5speed)
I'm looking to install a remote starter on my 06 Civic DX (5 speed manual).
Installation should be extremely easy for it since it doesn't have power door locks or any factory alarm system right?
From what i've gather, it should be 7 wires total to connect.
- Power
- Ground
- Ignition
- Starter
- Tachometer
- Brake
- Parking lights
Am I missing anything? I bought this remote starter for a automatic but it shouldn't matter right?
Could someone shed some light onto where is the tachometer wire located? Ignition harness?
Old Sep 16, 2007 | 07:56 PM
candyman206's Avatar
Default Re: Installing a remote starter (kroze)
Sorry to be the one to do this. But nobody is going to give you that info. I say the next person to read this will give you that link with the picture of the Integra in a pile of bricks.
Old Sep 17, 2007 | 04:08 AM
B18C_EJ8's Avatar
If you install a starter specifically designed for 5-speeds, then yes, we will help you.
However, if you choose another brand not intended for manual transmission vehicles, you're on your own.
To the OP, you've got the basics down, however, you'll need to wire in the clutch switch so the car thinks you've pushed in the clutch before it'll remote start.
You could try http://www.bulldogsecurity.com for all of your wire colors & locations.
Old Sep 17, 2007 | 04:48 AM
fcm's Avatar
fcm
Old Fart
What is the make and model of the remote start? 94
Old Sep 17, 2007 | 04:50 PM
kroze's Avatar
Default Re: Installing a remote starter (fcm)
DEI 561R
Old Sep 17, 2007 | 05:04 PM
B18C_EJ8's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">If you install a starter specifically designed for 5-speeds, then yes, we will help you.
However, if you choose another brand not intended for manual transmission vehicles, you're on your own. </TD></TR></TABLE>
No DEI remote start is intended for a 5 speed.
Old Sep 17, 2007 | 05:28 PM
fcm's Avatar
fcm
Old Fart
No DEI remote start is intended for a 5 speed.</TD></TR></TABLE>
As stated in the install guide...
IMPORTANT! This product is designed for fuel-injected, automatic transmission vehicles only.
Installing it in a standard transmission vehicle is dangerous and is contrary to its intended use. 94
kroze
Honda Civic (2006 - 2015)
17
Feb 9, 2014 01:57 PM
Jaydeep
Audio / Security / Video
Oct 15, 2009 09:09 AM
greenblurr93
Dec 9, 2008 08:40 PM
vtecn8ive
Nov 15, 2008 12:52 PM
