civic type r tranny rebuild help
Old Sep 16, 2007 | 04:23 PM
anthonyfa18's Avatar
Default civic type r tranny rebuild help
ok my buddy need to rebuild his 98 civic type r tranmission, the barings and sycros are finish. now what i need to know is, do usdm integra type r tranmission parts fit and work in the jdm civic type r tranmission?? if not is there a site that have a oem honda jdm parts catalog so i can order the parts from the acura dealer i work at??
Old Sep 17, 2007 | 05:21 PM
Default Re: civic type r tranny rebuild help (anthonyfa18)
any help
Old Sep 18, 2007 | 05:27 PM
Quitripin's Avatar
you should get a oem service manual on helminc.com
Old Sep 19, 2007 | 04:42 PM
Default Re: civic type r tranny rebuild help (Quitripin)
ya i all ready have that, but what i want to know is do usdm type r parts fit in a jdm civic type r tramission
Old Sep 20, 2007 | 10:58 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yes. same transmission.
Old Sep 21, 2007 | 09:51 PM
Default Re: civic type r tranny rebuild help (not so civic)
r u sher because my boss (the part manager at my acura dealer) said thea they do not fit, he said usdm tranny are not the same as jdm is he right or worng???? has any one rebuild there jdm tranny with usdm parts?????
Old Sep 23, 2007 | 08:47 AM
yes i'm sure. i've been messing with hydraulic b series transmissions for 6 or so years.
Old Sep 23, 2007 | 05:43 PM
rookiepains's Avatar
not the same the countershaft splines are a bit thicker on jdm i tried it last week with an mfactory 3.07 1st gear on my jdm itr then sold it and installed it on b16 tranny fit like a glove..
Old Sep 25, 2007 | 06:08 PM
Default Re: (rookiepains)
so where can i get the part number for the jdm tranny parts
Old Sep 26, 2007 | 09:29 AM
ludedeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anthonyfa18 &raquo;</TD></TR><TR><TD CLASS="quote">ok my buddy need to rebuild his 98 civic type r tranmission, the barings and sycros are finish. now what i need to know is, do usdm integra type r tranmission parts fit and work in the jdm civic type r tranmission?? if not is there a site that have a oem honda jdm parts catalog so i can order the parts from the acura dealer i work at?? </TD></TR></TABLE>
What parts do you need?
Old Sep 26, 2007 | 01:28 PM
Default Re: civic type r tranny rebuild help (ludedeg)
sycros and barings
Old Sep 26, 2007 | 04:19 PM
PHDZINE's Avatar
The syncros and bearings are the same as the USDM GSR and ITR. The LS has a different 1st to 2nd Syncro...the rest are the same.
Old Sep 27, 2007 | 05:51 AM
ludedeg's Avatar
Default Re: civic type r tranny rebuild help (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">The syncros and bearings are the same as the USDM GSR and ITR. The LS has a different 1st to 2nd Syncro...the rest are the same.</TD></TR></TABLE>
Not quite
Hydro B16, GSR, TYPE R, CTR use all the same syncros. LS has smaller 3/4th syncro.
All the case bearings for the trans are the same on all hydro B series except for the diff.
B16/LS use the same diff bearings
GSR/ITR/CTR all can use the type R style ball diff bearing bearing.
This site will help you with partnumbers and pricing.
http://www.sonsacuraparts.com/sons/jsp/home.jsp
Old Sep 27, 2007 | 07:36 AM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedeg &raquo;</TD></TR><TR><TD CLASS="quote">Not quite
http://www.sonsacuraparts.com/sons/jsp/home.jsp</TD></TR></TABLE>
Forgot about that...smaller shift fork as well on the main input shaft.
Old Oct 7, 2007 | 11:26 AM
so this means i cant use the part fom a itr from here to re build my buddy tranny
Old Oct 7, 2007 | 11:22 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anthonyfa18 &raquo;</TD></TR><TR><TD CLASS="quote">so this means i cant use the part fom a itr from here to re build my buddy tranny</TD></TR></TABLE>
hmm you cant read can you?
if it makes you feel any better i spoke to bense about this a loooong time ago and yes the usdm ITR parts are the same as the CTR.
you can also talk to the people over at gearspeed for parts/advice etc...
boostd ls
18
May 10, 2007 05:33 PM
X2BOARD
Aug 29, 2006 01:13 PM
B-A-N-A-N-A-S
May 31, 2005 08:26 PM
RuffRhyno
Sep 29, 2003 06:08 PM
vtecmissle
May 22, 2003 12:01 PM
