Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
NEED HELP!!! weird noise
Old Sep 16, 2007 | 12:44 PM
crazybluecivic's Avatar
Default NEED HELP!!! weird noise
my car in the mornings has just started making a loud whistle when i rev above 2 or 3 rpm its loud and sounds like something grinding or lose i dunno please help it sounds like crap but it goes away after a lil driving or i just cant hear it anymore
ive check my oil just incase see if its low its still gold but its way above the first hole coming down actualy when i pulled the dip stick out the whole thing had oil on it can this be it TOO much oil? i dunno please help
Old Sep 16, 2007 | 12:51 PM
toyomatt84's Avatar
Sanji
Put your car in neutral, pull the e-brake, and rev the engine using the throttle body. Try and pinpoint where the noise is coming from. There could be nearly anything causing that noise, so it's near impossible to give a justified reason as to why it's making noises.
Old Sep 16, 2007 | 01:03 PM
Default Re: (toyomatt84)
ive done that and i realy can pin point it it almost most likely sounds like its coming from the engine it self but it also sound like it could be electrical whistle
Old Sep 16, 2007 | 01:12 PM
toyomatt84's Avatar
Sanji
Default Re: (crazybluecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazybluecivic &raquo;</TD></TR><TR><TD CLASS="quote">ive done that and i realy can pin point it it almost most likely sounds like its coming from the engine it self but it also sound like it could be electrical whistle</TD></TR></TABLE>
Well, unfortunately, you're not being descriptive enough for me to pinpoint your problem.
Old Sep 16, 2007 | 01:51 PM
sorry toy i realy cant pinpoint it myself see our issue
Old Sep 17, 2007 | 08:36 AM
mikelax125's Avatar
* B A N N E D *
if you have an after market stereo system. it could be a bad ground. if it sounds like u have a really ******* big turbo when u rev then thats probably what it is.
Old Sep 17, 2007 | 09:03 AM
thinknology's Avatar
Default Re: NEED HELP!!! weird noise (crazybluecivic)
ive check my oil just incase see if its low its still gold but its way above the first hole coming down actualy when i pulled the dip stick out the whole thing had oil on it can this be it TOO much oil? i dunno please help </TD></TR></TABLE>
What did you do check your oil while the car was running?
Old Sep 17, 2007 | 06:06 PM
Rendition's Avatar
Default Re: NEED HELP!!! weird noise (thinknology)
bring it to dealership
Old Sep 17, 2007 | 08:51 PM
Default Re: (mikelax125)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikelax125 &raquo;</TD></TR><TR><TD CLASS="quote">if you have an after market stereo system. it could be a bad ground. if it sounds like u have a really ******* big turbo when u rev then thats probably what it is. </TD></TR></TABLE>
realy i do have a aftermarket sterio but it stops i would think it would continue
and no i didnt check the oil while it was running
Old Sep 18, 2007 | 02:55 AM
and no i didnt check the oil while it was running</TD></TR></TABLE>
Well if you have oil all the way up the dipstick... usually not good...
I'd say take it to the dealer, it sounds like your over your head, IMO. :shrugs:
VihnSta2
Mar 9, 2010 07:04 AM
santacruzccs
Aug 15, 2007 02:14 PM
es_squared
Mar 15, 2007 06:48 PM
SiR HatchAlot
Sep 4, 2003 09:51 PM
el arbi
15
May 18, 2003 09:06 AM
