Which ECU?
Old Sep 16, 2007 | 09:35 AM
standbackimapro's Avatar
Default Which ECU?
B16A, the kid has a OBD0 ecu in it, is this the correct ecu for it, or should it be running somthing else
Old Sep 16, 2007 | 12:02 PM
Redline130's Avatar
Default Re: Which ECU? (standbackimapro)
What car is the motor in?
Old Sep 17, 2007 | 07:00 AM
a 90 integra, the ecu in it now is a pr3
Old Sep 17, 2007 | 07:59 AM
Relic1's Avatar
PR3 = OBD0 B16A ECU.
Old Sep 17, 2007 | 09:21 AM
MR_FIX_IT's Avatar
Default Re: (Relic1)
^hes right..................PR3=88-91 JDMB16A EF8/9/Integra XSi
Old Sep 17, 2007 | 10:19 AM
Ok, well would a different ECU be a direct plug in and offer any more performance
and also i dont understand how to read this obd LED for the codes
the led on the ecu comes on stays on for about 5 seconds, then it blinks 5 times stops, has a quick blink but longer then the other blinks, then blinks 5 more times
and on the sheet i have there is nothing for 5 blinks, but 6 blinks is a coolant temp sensor,
what happens is at idle the check engine light wasnt on, and after a few minutes of spirited driving the light comes on and stays on and has been on
Old Sep 17, 2007 | 12:09 PM
MR_FIX_IT's Avatar
Default Re: (standbackimapro)
i dont know if u could find one but i belive a PW0 would work as well. its out of the euro/jdm B16a's...i belive it has a more aggressive timing map but dont quote me on that........and as far as ur CEL i think it could be O2 sensor
Old Sep 17, 2007 | 12:48 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">Ok, well would a different ECU be a direct plug in and offer any more performance</TD></TR></TABLE>
PW0 maybe, but minimal if any difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and also i dont understand how to read this obd LED for the codes
the led on the ecu comes on stays on for about 5 seconds, then it blinks 5 times stops, has a quick blink but longer then the other blinks, then blinks 5 more times </TD></TR></TABLE>
when you first switch on the ignition the CEL will be on for 5 seconds for the bulb check, then the CEL will start flashing.
I'm confused by your description as to which is a long blink and which is short blink.
short blink = ones digit (1-9)
long blink = tens digit (10-90)
my guess based on your description, 5 & 15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and on the sheet i have there is nothing for 5 blinks, but 6 blinks is a coolant temp sensor,
what happens is at idle the check engine light wasnt on, and after a few minutes of spirited driving the light comes on and stays on and has been on</TD></TR></TABLE>
5 = MAP sensor (machanical problem) http://www.b18c5eg.com/CELs.htm
Old Sep 17, 2007 | 06:42 PM
b18c1ej8's Avatar
i think the pr3 should be alrite, i even ran a chipped pr3 on my gsr in my da and it ran ****** awesome compared to my p72
crxtreme27
Jul 1, 2003 04:30 PM
hybridb18
Mar 29, 2003 09:12 PM
GeeSeeR
Sep 18, 2001 06:30 PM
