10 second First Geb B16A possible ???
10 seconds maybe a little far pitched . but im looking at upgrading to Type R cam's OBD1 Type R Intake Manifold. ect ect i was told 180 HP by just doing that.... what other mod's is there i can do ? what is the most this engine can handle ....
-Rob-
-Rob-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR_Injected »</TD></TR><TR><TD CLASS="quote">10 seconds </TD></TR></TABLE>
Not going to happen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR_Injected »</TD></TR><TR><TD CLASS="quote">180 HP by just doing that</TD></TR></TABLE>
Not likely.
Get Omni's B16 DVD to get an idea of what a B16 can do, done properly.
Not likely.
u can hit 13's in a light car with a modded engine. but to run 10's with an n/a b16 ur looking at some serious work. i mean its hard enough to make 200whp with a b16 let alone enough to propell u into the 10's.
either go boost or build the hell out of it and run slicks. theres a hell of alot more than just weight and hp that can determine ur quarter mile times. for one elevation is a biotch cause the elevation will starve your motor. bolt ons alone will not get u into the 12's.
at this point a first gen b16 is tired and probably on it's last leg. ditch the block for a b18c and you're on your way to happyland.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">at this point a first gen b16 is tired and probably on it's last leg. ditch the block for a b18c and you're on your way to happyland.</TD></TR></TABLE>
ls vtec
as for ITR cams nd IM in a b16 ... i'd say you'll be lucky to hit 13s
ls vtec
thats *NFG* lol my b16 aint tired. not yet anyways. i guess ill have to look at getting a b18 .. it pretty much sums it up b16 isnt possible..
nek9
43
Jun 22, 2006 05:14 PM
