what header for 00' coupe with b18? need help asap!!
Old Sep 15, 2007 | 06:36 PM
Lordofdark176's Avatar
Default what header for 00' coupe with b18? need help asap!!
i have a 2000 civic ex coupe with an ls/vtec swap (b18b1 bottom end, b16 head). right now im using a dc header thats kinked and when i bolted it on, it didnt meet up with the cat bolted to the rest of the exhaust. it was like 1 foot too short. so i took it to an exhaust shop and they extended the exhaust piping to make it bolt up. well now im looking for an upgrade (currently running stock piping) so im wondering what header i need to get that will bolt up to the stock d series cat and a catback for a 00 coupe that wont require any hacking up of the exhaust piping. is it true that a b16 header wont clear the bottom of the oilpan? if it will clear it, would it bolt up to the cat and a catback with no length issues? need help asap!
Old Sep 15, 2007 | 06:59 PM
crazyguy's Avatar
Default Re: what header for 00' coupe with b18? need help asap!! (Lordofdark176)
what kind of dc header u are using ? for gsr or for LS ? 2 piece design or 1 piece?
Old Sep 15, 2007 | 07:04 PM
unsure if its a gsr or ls, is one short and one long? also its a 4-1. im just trying to figure out what im going to have to do header wise to make my new exhaust system all bolt up cleanly and not be welded into 1 piece lol.
im picking up a stock ls header this weekend, is it not going to work with my setup right now then????
Old Sep 15, 2007 | 07:07 PM
crazyguy's Avatar
Default Re: (Lordofdark176)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 &raquo;</TD></TR><TR><TD CLASS="quote">unsure if its a gsr or ls, is one short and one long? also its a 4-1. im just trying to figure out what im going to have to do header wise to make my new exhaust system all bolt up cleanly and not be welded into 1 piece lol.
im picking up a stock ls header this weekend, is it not going to work with my setup right now then????</TD></TR></TABLE>
i have the same problem too.as i am trying to find a aftermarket header for my b16a swap...
Old Sep 15, 2007 | 07:25 PM
bump
Old Sep 16, 2007 | 07:26 AM
ttt
Old Sep 16, 2007 | 09:25 AM
00Red_SiR's Avatar
All Motor Mentor
B16 header won't work. You'll need a header for the type R b18c5 (b18c1 header is slightly shorter I think). You still will need to extend your exhaust a little or find a type R cat....You'll need a cat/extension (or test pipe) about 17 inches long if memory serves to join the header to the cat back. I have a b18c5 in my EM1 and use the JDM DC 4-1 header and I had to buy a larger cat with an extension pipe welded to it to work for me.
Old Sep 16, 2007 | 06:08 PM
ok thanks. can anybody else add to this?
Old Sep 16, 2007 | 06:11 PM
SlaMMedB16's Avatar
My buddy has a LS-V in his hatch and right now he has an Apexi 4-2-1 and King Motorsports told him that with an ls-v that a ITR header would work better than the apexi. Its not much but thats my 2 cents worth. There reasoning is that the ITR header would do better with the compression ratio.
Old Sep 16, 2007 | 07:18 PM
im more concerned about whats going to fit with minimal to no cutting and welding needed.
Old Sep 17, 2007 | 09:48 AM
SlaMMedB16's Avatar
hmm, well all i can say is i tried...idk what to tell you dude. Sorry
Old Sep 17, 2007 | 02:18 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 &raquo;</TD></TR><TR><TD CLASS="quote">im more concerned about whats going to fit with minimal to no cutting and welding needed.</TD></TR></TABLE>
Pretty sure you're only option will be a JDM DC 4-1 type R header and a cat that ends up being 17" long. Another alternative for you may be the Rage tri-y style (Hytech) header which is longer than stock. It would either bolt up or come close. You might have trouble running a cat with it though because of it's length or modify the b-pipe to make them work together.
Old Sep 17, 2007 | 06:32 PM
bah looks like im gonna need to get it all fabbed up. ohwell thanks for the help everybody.
w0nd3r
Jan 15, 2008 12:59 PM
phanatic
Jun 11, 2006 07:42 AM
BlueIntegraBoy
Jul 30, 2003 05:56 AM
euclid
Jun 18, 2003 04:55 PM
