this is getting really frustrating for me.
Old Sep 15, 2007 | 04:28 PM
hassan21's Avatar
Default this is getting really frustrating for me.
can some one plz help me and guide me or something cuz ive done everything that i could think of.
my car keeps overheating.
i did the following:
-changed the thermostat
-changed the waterpump
-flush the raditor
-bought a new raditor cap
-bleed the cooling system
-fans works fine
is there anything that i can do?
i really need the help.
Old Sep 15, 2007 | 04:34 PM
godruler's Avatar
Default Re: this is getting really frustrating for me. (hassan21)
replace the headgasket
Old Sep 15, 2007 | 04:36 PM
hassan21's Avatar
can you give me instuctions on replacing the headgasket.
Old Sep 15, 2007 | 04:50 PM
SiR Inspired ED7's Avatar
Get another motor.....
Old Sep 15, 2007 | 05:51 PM
hassan21's Avatar
thats too expensive for me.
i dont think i have that kind of money.
can someone plz help me?
Old Sep 15, 2007 | 05:57 PM
boosted91crx's Avatar
When does it overheat? and when did it start? any other issues with the car?
Old Sep 15, 2007 | 06:41 PM
VtecSyndrome's Avatar
Default Re: this is getting really frustrating for me. (godruler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godruler &raquo;</TD></TR><TR><TD CLASS="quote">replace the headgasket</TD></TR></TABLE>
Most likely cause
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hassan21 &raquo;</TD></TR><TR><TD CLASS="quote">can you give me instuctions on replacing the headgasket.</TD></TR></TABLE>
Step 1: Remove head
Step 2: remove and clean up old gasket material
Step 3: install new head gasket
Step 4: install head
Step 5: Pay and thank your local Honda tech for a job well done and for helping you avert sure catastrophe by tying this yourself when your obviously not qualified to do so
Old Sep 15, 2007 | 07:33 PM
Red_ED8's Avatar
How exactly did you bleed the cooling system?
Old Sep 16, 2007 | 12:40 AM
hassan21's Avatar
naw thats the only problem it has been overheating like crazy i replaced all that stuff bcuz thats what ppl told me to do.
i bleed the cooling system by starting the car turned on the heater and open the bleeding *** and waited till water squited out
Old Sep 16, 2007 | 09:53 AM
GoFastTshirts.com's Avatar
Default Re: (hassan21)
any white smoke ? Probably a head gasket
Old Sep 16, 2007 | 10:38 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (GoFastTshirts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoFastTshirts.com &raquo;</TD></TR><TR><TD CLASS="quote">any white smoke ? Probably a head gasket</TD></TR></TABLE>
Could be.
OP, get a compression test done.
Old Sep 16, 2007 | 10:05 PM
hassan21's Avatar
hmmm there is white smoke but only for a few seconds when i start up.
yes i did a compression test.
it came out fine.
im thinking maybe my raditor?
im going to get that soon.
Old Sep 17, 2007 | 08:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hassan21 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm there is white smoke but only for a few seconds when i start up.
it came out fine.
im going to get that soon.</TD></TR></TABLE>
Why not just buy a whole new car with that mentality, just throwing parts at it til it's fixed uh? you sound like one of those guys that says it's too expensive to let a tech work on my car so I'll just spend all my money on parts til it's fixed...why not just throw a new heater core, hoses, fans and a new gauge cluster in as well? you have not done that yet maybe that will fix it
Old Sep 17, 2007 | 08:31 AM
hondaownr's Avatar
do an oil change if your oil is a coffee color it is the headgasket..
Old Sep 17, 2007 | 08:44 AM
Hondaisok's Avatar
Default Re: (hondaownr)
Coffee color? without cream and sugar? You can also get that color when you don't change your oil for a while. You can also have the radiator water tested for hydrocarbons which would point to a headgasket problem.
Old Sep 17, 2007 | 07:31 PM
welfarepc's Avatar
you didnt bleed your coolant long enough. make sure it spews out solid coolant for atleast 5 minutes
dont forget to top up while bleeding
GREENMOB$TER
Feb 8, 2007 09:15 PM
93civicExSI
Jul 9, 2006 05:26 AM
DB1_559
Jun 8, 2006 09:10 AM
delsolb16
Sep 21, 2005 07:15 PM
drkblue_civic
12
Oct 2, 2003 10:40 AM
