Block guard...is it worth it?
Old Sep 15, 2007 | 03:58 PM
TDogg Teg's Avatar
Default Block guard...is it worth it?
Sup, guys! I'm looking to rebuild my boosted 95 LS block with aftermarket CP 9.0:1 pistons and Eagle rods, and wanted to inquire about block guard. I know sleeving the block is the way to go, but dont have the cash for them, not to mention the labor costs for a qualified machine shop to install them, I cant believe the tolerances on those things!
Will the block guard work just as good for boosted applications? Any info will be appreciated.
Old Sep 15, 2007 | 04:32 PM
doood's Avatar
been there done that
Default Re: Block guard...is it worth it? (TDogg Teg)
dont bother. stock sleeves can hold 350-400whp. more if you're feeling lucky.
Old Sep 15, 2007 | 05:37 PM
TDogg Teg's Avatar
Default Re: Block guard...is it worth it? (doood)
And thats the range Im aiming to hit with the proper tuning and boost. Im currently running a Precision T3/T4 .48/.63.
Old Sep 15, 2007 | 10:20 PM
GLI's Avatar
GLI
Well the guard would be better than stock. IMO I would do the block guard. Stock sleeves and pushing 350hp is just asking for catastrophe. You can post the block if your not going to use the block guard/sleeve.http://homemadeturbo.com/tech_....html
Old Sep 15, 2007 | 10:26 PM
doood's Avatar
Default Re: Block guard...is it worth it? (GLI)
block posting is ghetto. the amount it would cost to properly install a block guard is better spent towards sleeves.
Old Sep 16, 2007 | 06:30 AM
TDogg Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">block posting is ghetto. the amount it would cost to properly install a block guard is better spent towards sleeves.</TD></TR></TABLE>
Talked to a local machine shop from around the way that deals with a lot of racecars, and they gave me a reasonable rate to do my block. I may bite the bullet and eat cold cuts for a while and sleeve it.
Not gonna take any chances, cuz a stock block and a boost addiction is NOT a very good combo, haha!
Old Sep 17, 2007 | 12:09 PM
CerealKiller's Avatar
IMO block guards are only good for 1 thing and that is saving your block from becoming non resleevable. So if your flirting with disaster, I believe its good to install a block guard, It'll save you money on the long run. Just my 0.02
Old Sep 17, 2007 | 02:31 PM
BILLETGRIP's Avatar
Default Re: Block guard...is it worth it? (inlineaddict)
block gaurds are pointless unless they are welded in or custom made for your block https://honda-tech.com/zerothread?id=1959207 &lt;-------and this is why i think that
Old Sep 17, 2007 | 07:25 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDogg Teg &raquo;</TD></TR><TR><TD CLASS="quote">
Not gonna take any chances, cuz a stock block and a boost addiction is NOT a very good combo, haha! </TD></TR></TABLE>
i wouldnt trust just any machine shop to do sleeves in a honda. they're totally different than doing them for a v8 or something.
Old Sep 19, 2007 | 12:20 PM
TDogg Teg's Avatar
When I say racecars, i mean in general. I found out they deal with 4 cyl. engines as well as v8's, including B-series motors. Met a guy named Jerome that had his block and head fully done there.
Didnt realize they were under my nose all the time.
Old May 15, 2008 | 09:34 AM
Elwuudz's Avatar
I've seen some ls/vtec on here running 600+whp with a block guard
I would use it as cheap insurance for a N/A engine, when boring and honing
Don't just press it in; have a machine shop weld it in and rehone the cylinder walls
I have since been adivised: block guards aren't nessesarry and cause hot spots
Modified by Elwuudz at 5:14 PM 5/15/2008
blackccoupe
Oct 14, 2010 10:28 PM
marksturboek
Apr 23, 2006 03:02 PM
s2kdre
Apr 29, 2005 07:21 PM
Rod.
Sep 12, 2003 10:51 PM
CIVICNONVTEC
Aug 23, 2003 06:00 AM
