Y80 rebuilt question
Old Sep 15, 2007 | 03:37 PM
munnellphotography's Avatar
Default GSR trans rebuild question
Experienced techs,
Recently finished dismantling my Hydro GSR trans and replacing some bearings and seals. Have driven appox 1k uneventful miles since...
When I reassembled the transmission, I neglected to install the 3rd/4th and 5th synchro hubs and 4th and 5th gears un-lubricated and with a press (as is instructed in the Helm's manual) - they were lubed, and easily slid into place, like every other mainshaft component. The re-assembly went smoothly, the trans case fit back together like a glove, and I haven't noticed any odd behavior since. Should I go to the trouble of dropping trans to disassemble / reassemble 3rd/4th and 5th with a press, unlubed, or just leave well enough alone?
Is the "dry/press" assembly of 3rd/4th, and 5th absolutely crucial, or just suggested? And if necessary, why?
Thanks in advance,
Luke
Modified by munnellphotography at 4:49 PM 9/15/2007
Modified by munnellphotography at 5:19 PM 9/15/2007
Modified by munnellphotography at 5:20 PM 9/15/2007
Old Sep 17, 2007 | 10:48 AM
DontBlink's Avatar
Default Re: GSR trans rebuild question (munnellphotography)
bump
Old Sep 17, 2007 | 12:06 PM
Mista Bone's Avatar
D Tranny Guru
press not needed.......add the require amount of fluid......start car in nuetral on stands and let run for 5 minutes.
You should be fine.
bennyBronco
Sep 8, 2011 09:06 AM
ohsnapzafingcu
Transmission & Drivetrain
Apr 2, 2011 11:12 PM
CR-V-tech
Mar 7, 2008 03:59 PM
junbb1
Mar 26, 2005 12:14 PM
Vexamus
Oct 2, 2002 02:48 AM
