fuse 14 keep blowing
Old Sep 15, 2007 | 10:18 AM
jdm206's Avatar
Default fuse 14 keep blowing
ok im having a hard time trying to find out where the short is at. has anyone ever had this problem?
Old Sep 15, 2007 | 10:46 AM
Crx dude's Avatar
Default Re: fuse 14 keep blowing (jdm206)
Thats your alternator and solenoid valve fuse. Does it pop when the key is forward or
when you just put the fuse in? check the wires going to your alternator make sure they aint grounding out.
Old Sep 15, 2007 | 11:44 AM
jdm206's Avatar
Default Re: fuse 14 keep blowing (Crx dude)
when i turn the key to the on postion it just keeps blowing out. also do this fuse control the main relay?
Old Sep 15, 2007 | 12:15 PM
boosted91crx's Avatar
Not sure on hondas but on some other cars the key switch it self going bad does things like this.
Old Sep 15, 2007 | 12:23 PM
jdm206's Avatar
Default Re: (boosted91crx)
so should i just put a new key switch? is it also bad to put a bigger fuse in the spot.
Old Sep 15, 2007 | 12:27 PM
let some one who is more familiar with honda ignition switches then me confirm that this may be the issue, and as far as a larger fuse , dont put in one thats larger then factory.
Old Sep 16, 2007 | 11:12 AM
jdm206's Avatar
ok, should i just try where the short is coming from?
Old Sep 16, 2007 | 03:31 PM
GLI's Avatar
GLI
Default Re: (jdm206)
Do you have a kill switch? My switch was contacting some metal, so I just wrapped it up with electrical tape and that solved my fuse blowing foolishness.
Old Sep 16, 2007 | 03:52 PM
Tippyman's Avatar
Default Re: (GLI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GLI &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a kill switch? My switch was contacting some metal, so I just wrapped it up with electrical tape and that solved my fuse blowing foolishness.</TD></TR></TABLE>
Same here. Your fuel pump is on the same circuit.
Old Sep 16, 2007 | 09:41 PM
jdm206's Avatar
Default Re: (Tippyman)
i dont have a kill switch. all i did was change my fuel pump to a walbro one. can that be the problem?
Old Sep 17, 2007 | 08:00 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm206 &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a kill switch. all i did was change my fuel pump to a walbro one. can that be the problem?</TD></TR></TABLE>
That's definitely it.
the fuel pump is on the same circuit. Find out where you fucked up the wiring and fix it.
Old Sep 17, 2007 | 11:59 AM
jdm206's Avatar
ok i will be checking the fuel pump tomarow.
Civic-Kids
Audio / Security / Video
Feb 22, 2010 10:30 AM
Fly1865
Jun 18, 2004 05:48 PM
MeanGreenEG9
May 6, 2003 10:17 AM
ModlesSI
Feb 22, 2003 03:16 PM
