92 hatch roof?
Old Sep 15, 2007 | 05:54 AM
ghostcivic's Avatar
Default 92 hatch roof?
this might sound dumb but i have been told the roof of the 92-95 hatch bolts off. does anybody know if this is true?if so would it be possable to swap roofs with a hatch that had a sunroof?i know i will need the wiring to but thats not a problem. thanks everybody
Old Sep 15, 2007 | 07:01 AM
ghostcivic's Avatar
Default Re: 92 hatch roof? (ghostcivic)
bump for an answer
Old Sep 15, 2007 | 07:41 AM
jayjay's Avatar
The roof is welded on and you would need to drill out all the factory welds both on your car and the donor car.
Old Sep 15, 2007 | 07:54 AM
instrument's Avatar
the welds are hidden by the rain guard things.
does a good job of hiding the damage.
Old Sep 15, 2007 | 08:04 AM
ghostcivic's Avatar
Default Re: (instrument)
are they spot welds or is it a solid weld? do u think aftermarket sunroof would be easer? witch would look better?
Old Sep 15, 2007 | 08:24 AM
RCautoworks's Avatar
Default Re: (ghostcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostcivic &raquo;</TD></TR><TR><TD CLASS="quote">are they spot welds or is it a solid weld? do u think aftermarket sunroof would be easer? witch would look better?</TD></TR></TABLE>
Spot welded, if you look around you will see threads of people putting sun roofs in. Its not an easy task.
Old Sep 15, 2007 | 08:28 AM
philosofy1's Avatar
Default Re: (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">
Spot welded, if you look around you will see threads of people putting sun roofs in. Its not an easy task. </TD></TR></TABLE>
anything dealing with drilling out spot weld is not easy. IMO, the op should just leave the roof alone. it's not worth the trouble.
Old Sep 15, 2007 | 08:48 AM
DeucesWild's Avatar
there are drill bits that you can purchase at..... sears i think???...... that will do a better job of removing the spot welds, leaving more metal to weld to.
BUT, imho if you are not very skilled with body work (welding, drilling, painting, sanding, etc.), this would not be a task that i would attempt to accomplish without professional help.
Old Sep 15, 2007 | 08:52 AM
shadohconspiracy's Avatar
it would be scary if the roof was only held on by a few bolts
Old Sep 15, 2007 | 08:54 AM
Default Re: (DeucesWild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeucesWild &raquo;</TD></TR><TR><TD CLASS="quote">there are drill bits that you can purchase at..... sears i think???....</TD></TR></TABLE>
If you don't get a good bit, its going to suck. There is a thread about this in the welding section.
Old Sep 15, 2007 | 09:03 AM
EK9Rider's Avatar
search the archives - there's a guy that did the 92-95 sunroof swap - detailed pics of the removal and donor swap..
it's not easy but IMO it's worth it -- i would do if i could
i might be listed under "sunroof"
you have to search for a while....
jxhxb
Dec 20, 2007 12:51 PM
zccr-xsi
12
Dec 1, 2005 06:22 PM
_Cyclone_
11
Jul 20, 2005 09:42 AM
cisurfer1
Apr 16, 2005 04:35 PM
Eyes Only
45
Aug 28, 2003 07:05 PM
