Greddy Boost Controller Profec B spec 2
Old Sep 14, 2007 | 08:03 PM
nitroice40's Avatar
Default Greddy Boost Controller Profec B spec 2
Just hooked this bitch uo and I am not sure if I am missing something. I have it in psi not 100kpa, at idel its at -99 and at about 3 or 4 psi its reading 29 and the alarm is going off. Could that be 2.9psi? But at idel its at -99 that cant be 9.9 because my manual boost guage is reading about 20.
please any help
Old Sep 14, 2007 | 08:38 PM
turboekcivic's Avatar
Default Re: Greddy Boost Controller Profec B spec 2 (nitroice40)
what did you set your warning at? i just put mines in too.. try setting your warning 1 psi higher then your set psi..
Old Sep 15, 2007 | 07:31 AM
nitroice40's Avatar
Default Re: Greddy Boost Controller Profec B spec 2 (turboekcivic)
I set low at 18 and warning at 20. At about 3psi the warning was going off.
Old Sep 15, 2007 | 07:55 AM
PA MATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitroice40 &raquo;</TD></TR><TR><TD CLASS="quote"> But at idel its at -99 that cant be 9.9 because my manual boost guage is reading about 20.
More than likely, your boost gauge is reading vacuum as in/hg at 20 and the ebc is reading in psi at 9.9. 9.9 in psi is the same as about 20 in/hg....just throwing my $0.02 out there
Old Sep 15, 2007 | 06:15 PM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitroice40 &raquo;</TD></TR><TR><TD CLASS="quote">Could that be 2.9psi? But at idel its at -99 that cant be 9.9 because my manual boost guage is reading about 20.
please any help</TD></TR></TABLE>
the EBC reads PSI in x10 format. so a reading of 70 would be 7 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote">
More than likely, your boost gauge is reading vacuum as in/hg at 20 and the ebc is reading in psi at 9.9. 9.9 in psi is the same as about 20 in/hg....just throwing my $0.02 out there</TD></TR></TABLE>
yes and 9.9 PSI would read as 99 on the EBC or (-99 in the case of vacuum)
Old Sep 15, 2007 | 07:15 PM
Default Re: Greddy Boost Controller Profec B spec 2 (oranginal)
are you sure its hitting warning at 3psi? something is wrong unless your spiking really bad... check your peak
forcefedh22
Feb 9, 2005 02:39 PM
kcjohnnyboy
Dec 31, 2003 12:52 PM
jdm civic
Jan 27, 2002 05:48 AM
