Transmission leaking...
Old Sep 14, 2007 | 02:13 PM
johnclaunch's Avatar
Default Transmission leaking...
I have an 05 EP3 with 44K. The transmission started to leak slightly right after the warranty expired. Now, it is not leaking enough to drip. It only leaks enough to coat the transmission in a layer of fluid. I change the fluid every 10K with Redline MTL (overkill I know, but I change my Redline oil every 2.5K). It has been about 5K since the last change, and I checked the fluid, and it is full. This leak was pre-existing before the last change, so it was nothing the shop did. I have taken it to two different transmission shops and both are quoting me $400 just to remove the transmission and re-install it. It will go to the dealer next week for a quote but I am expecting somewhere in the same ballpark. It is leaking sightly onto my clutch causing slight slippage during hard acceleration.
Has anyone had this issue with their EP? What was the problem/fix/cost?
On a sidenote, $400 to remove and re-install the transmission; a clutch job must be expensive. Performance clutch ($400) + Flywheel ($250) + labor ($400) = $1050!! WTF??
Thanks.
Old Sep 14, 2007 | 05:57 PM
solidsounds's Avatar
Default Re: Transmission leaking... (johnclaunch)
i don't know anything about that but it sounds like a front seal and if you know how to pull tha tranny it's not to hard but 400 is about ballpark for a tranny pull
Old Sep 14, 2007 | 05:58 PM
WhiteOnRice's Avatar
Sounds like the overkill didn't do anything for you! But maybe try going to Honda even though you are barely over warranty. Maybe they will give you a real good deal.
secur60
Oct 15, 2017 01:49 AM
ekcoupe88
14
Sep 24, 2007 07:39 AM
PatrickGSR94
Jan 13, 2007 03:00 PM
phantom_sol
13
Sep 9, 2003 03:22 PM
AndyD
Oct 3, 2002 09:05 AM
